- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
2500 Extender will not connect
- Mark as New
- Bookmark
- Subscribe
- Permalink
My 2500 extender suddenly stopped working today and would not reconnect. With the guidance of a Verizon tech support person, I did power recyclings and a factory reset on both it and my Verizon Gateway router and used the Netgear Genie repeatedly, but it would not connect to the router.
I will appreciate any suggestions. Using the Netgear paid support would cost as much as buying a new extender.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 2500 Extender will not connect
Hello DavidMZ
Make sure your router is using WPA2 security type you may also want to change the wireless channel on the router. You could also try to use WPS to attach the extender.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks Darren, I tried the first and third and will try the second.
• Yes! WiFi 7 is backwards compatible with other Wifi Devices? Learn more
