× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
AC1200 won't connect with xfinity xb8 router
gcwest007
My old AC1200 worked fine with my older Xfinity router, but can't connect to my new XB8.  I've tried the WPS setup, Nighthawk app, website setup, and all the other recommended options, including add the MAC address into my XB8. After spending over 4 hours, I'm ready to ask for help.  For all I know, this old unit isn't even compatible with the newest routers.  I curse Xfinity for upgrading my router.  Advice?
Message 1 of 4
Guru
Re: AC1200 won't connect with xfinity xb8 router
Might check to see if WPA3 security on the wifi is present. Older generation device don't like newer versions of WPA, even if they don't support it.
Message 2 of 4
gcwest007
That could be it.  The router has WPA3, but the connection to the Netgear only shows WPA2.  Sounds like I need a new extender.  Jim
Message 3 of 4
Guru
Try disabling security on the new router for temporary to see if the NG extender will connect at all.
Re-enable after testing.
Probably.
Message 4 of 4
Discussion stats
  • 3 replies
  • 259 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
