×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
AC750 WiFi range extender, model EX6100v2
Semajynnep
Tutor
I can't get the extender to recognize my router. The router link led shows no connection. Worked fine for 2 years, but stymied now. Tried reset factory settings and reconnecting, but no connection.
Message 1 of 6
Accepted Solutions
afmarsh
Guide
Re: AC750 WiFi range extender, model EX6100v2
I started another thread, go here for the solution: https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/EX6100v2-will-not-connect-to-router/...
"...see if disabling SON helps by logging into router at myfiosgateway.com and go to Wireless Settings/Advanced Security Settings/ Other Advanced Wireless Options/Self-Organizing Network Enabled and set to Off"
Worked for me.
Message 5 of 6
All Replies
Guru
what router are you connecting to?
Are you setting up via wps or using the installation wizard?
Firmware on the extender?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 6
afmarsh
Guide
I have the same issue. Worked great this past year+, the other day just stopped. Router link LED off. Have updated firmware, reset to factory, and tried to setup all 3 ways (WPS, "Genie" and Nighthawk app). Sees the router, sets up a 2EXT and 5EXT but no connectivity.
NO changes to Fios Quantum Gateway router; no issues with any of the other dozen wifi devices in the house. I am: totally stumped.
Model: EX6100|AC750 Dual Band WiFi Range Extender
Message 3 of 6
Semajynnep
Tutor
I have a Verizon Fios router. No problems with other devices (ipad, iphone). I tried both WPS and Netgear installation assistant, but no connection between extender and router.
Message 4 of 6
afmarsh
Guide
Worked for me.
Message 5 of 6
Semajynnep
Tutor
Eureka!!!
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1065 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
