markgrant
Apr 19, 2018Aspirant
All lights GREEN but no _EXT network appears
Mac OSX 10.13.4
iOS 11.3 - 6th gen iPad, iPhone 6
WPS set-up went smoothly and lights are all GREEN on the extender, except the DEVICE light which is nothing, neither green nor red. And no _EXT network has shown up. So I can't connect my devices to the extender.
mywifiext.net says no connection. mywifext.local does not exist.
Have you tried to factory reset the unit by holding the reset button for 10+ seconds then try to set up the extender again? Then try to give it a different SSID when in the setup process.
DarrenM
- DarrenMSr. NETGEAR Moderator
Try to connect to the extender again VIA www.mywifiext.net login and try changing the SSID see if that shows up to your devices.
DarrenM
