Orbi WiFi 7 RBE973
Reply
Can I use one NETGEAR Range Extender EX8000 as AP and second one as Extender and mesh will work?
Tomalla
Follower
I have a Router from my ISP which gives me WiFi for ground floor. On the first floor I want to add EX8000 connected with ISP Router by Ethernet cable as an AP. Then I want to add second EX8000 as Range Extender on my attic.
The main question is about the mesh system: will roaming work seamlessly between all three devices?
Model: EX8000|AC3000 Nighthawk X6S Tri Band WiFi Mesh Extender
Message 1 of 2
Accepted Solutions
Guru
Re: Can I use one NETGEAR Range Extender EX8000 as AP and second one as Extender and mesh will work?
No. when the EX8000 is hardwired in and running in access point mode, it doesn't act as a mesh node. The mesh function works when its in extender mode. You can name it with the same ssid as the router/other extender but they'll tend to be sticky.
Unless something's changed in the firmware on the mesh extenders @DexterJB
Message 2 of 2
All Replies
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 384 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
