- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can't Connect to my N300 Range Extender
- Mark as New
- Bookmark
- Subscribe
- Permalink
We changed wireless routers and now my WN3000RPv3 range extender router indicator won't light and I can't see the device on my wireless network manager to even get to step one. It worked fine previously.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can't Connect to my N300 Range Extender
Please try resetting your WN3000RPv3 to factory defaults: http://www.downloads.netgear.com/files/GDC/WN3000RPV3/WN3000RPv3_UM_2Sep2014.pdf
You can also connect your computer to the WN3000RPv3 via ethernet to complete the setup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi tomb2,
Can you please confirm the setup: Computer connected via ethernet to the WN3000RP didn't work?
Please disable your computer's internet during the process.
The router link LED off means that there is no connection. Depending on your router, you can also log in and set an access control so that only specific devices are allowed on your network. You can also set a static IP for your extender.
User | Count |
3 | |
1 | |
1 | |
1 | |
1 |
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
