× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Cannot login on router through browser
Sjorrit
Tutor
Hi all,
I bought a second hand EX8000. I performed a factory reset of the device and then did a setup of the EX8000 using the Nighthawk Android app. So far everything works great but I would like to manage / change some settings of the router through the browser which are not available in the app.
I can login on the app, change some settings etc. on the router.
But when I use the same credentials when logging in with various browsers on login page of the router (192.168.1.150), I get an error "Username and password do not match.".
I performed a password reset through the app for which I got a confirmation email so that seems to be working fine as well. But I still can't login with my email / password combo.
What am I doing wrong?
Firmware version = 1.0.1.1.240 (latest version)
Model: EX8000|AC3000 Nighthawk X6S Tri Band WiFi Mesh Extender
Message 1 of 5
Accepted Solutions
Guru
Re: Cannot login on router through browser
A reset should clear those out.
AFter the reset, try setting up using the browser and not the app.
That should let you start with the default admin/password option.
And you can customize it afterwards.
Message 4 of 5
All Replies
Guru
the user name password is:
login: admin
password is: password (default one).
If you changed that, you'd need the one you changed it to. But the login should be admin
Message 2 of 5
Sjorrit
Tutor
Thanks for your swift reply.
I tried using admin instead of my e-mailadress as login but It still doesn't work.
I also tried my old password from before the password reset (obviously also didnt work)
Can it be that, despite the factory reset, the login/password of the previous owner is still in use?
Message 3 of 5
Guru
Message 4 of 5
Sjorrit
Tutor
Yeah I wanted to prevent doing a factory set again. But solution works. Thanks!
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1833 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
