× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EAX20 AX1800 Mesh Extender won't connect to XR500 Nighthawk Router
candlebot
Tutor
Router Info:
Board ModelFirmware VersionDumaOS Name
NETGEAR XR500
V2.3.2.114
A7Legit
Extender Info:
EAX20 - AX1800 Mesh Extender
For some reason I cannot get my extender to provide internet access to connected devices. I have the router setup and the extender setup and it just recently stopped working.
I reinstalled the extender to my network, and it successfully connects to the network on the setup page and completes setup. However, I am unable to access webpages when connected to the extender. Attemped on multiple devices, multiple different people attemtped multiple devices. When I attempt to update the firmware I get "error: no internet connection"
But on the main extender status page (mywifiext . net or the local version) I get all green lights and strong connection indicators. So it seems like my extender is connected to my router but not passing the internet signal through to the connected devices.
Please let me know what other info I can provide to be helpful
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 12
Accepted Solutions
Guru
Re: EAX20 AX1800 Mesh Extender won't connect to XR500 Nighthawk Router
What actual version of firmware is on the extender?
Have you tried manually updating the extender, then doing a factory reset and reinstall?
https://www.netgear.com/support/product/eax20
Message 10 of 12
All Replies
Guru
did you set it up using wps?
If so, try factory resetting the extender and installing it using the installation assistant.
Message 2 of 12
candlebot
Tutor
Nope, I set it up using the installation assistant both times
Message 3 of 12
Guru
What gateway is the xr500 connecting to
Message 4 of 12
candlebot
Tutor
The router is connecting to 192.
Message 5 of 12
Guru
What modem/gateway does the XR500 connect to to get signal?
Did you try setting up the EAX20 using wps?
Message 6 of 12
candlebot
Tutor
Sorry about that, Docsis 3.1
Message 7 of 12
Guru
that's not a model. Its a standard
https://en.wikipedia.org/wiki/DOCSIS
Message 8 of 12
candlebot
Tutor
Message 9 of 12
Guru
Message 10 of 12
candlebot
Tutor
THANK YOU, plemans!
Message 11 of 12
Guru
I take it that must have worked?
Glad to see it!
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 1938 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
