- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX6100
- Mark as New
- Bookmark
- Subscribe
- Permalink
EX6100
Hello eveyone, I recently purchased this item and set it up just as anextender, but it seems to have trouble staying connected to the main router. If I switch this router in to AP mode will I still be able to use the remaining 4 ethernet ports in the back as a switch. Or would I have to run a wire from a switch to the extender for the AP mode.
The instructions say that when in ap more you can only connect to it through wifi and the other ports become useless, but from what I read on amazon after the firmware is up to date I can use it as a AP and the other 4 as a switch.
I am Just looking for some clerity on the matter.
Thanks in advance for any help that can be given.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX6100
Hello Whyzgi
To use it in AP mode you would have to connect it via Ethernet and it would take up a port to do so. But if you are having issues with it staying connected via wireless I would suggest trying to adjust the wireless channel on you main router.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX6100
Ok I will try adjusting the channel, but my main question is. If I use it in ap mode will the other 4 act as a switch along with the cord that is pluged in for the ap mode?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX6100
I checked over the channels and those seem to be fine. When I tried to put it into the device into ap more, even though it is directly connected to the router, it says it can't fine a connection. I have the Direct link in the first slot.
User | Count |
3 | |
1 | |
1 | |
1 | |
1 |
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
