× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX6110 won't produce extender network NETGEAR_EXT
GrahamTate
Follower
Following instructions, using installation assistant, paragragh 1 states that upon plugging in the range extender near to the Hub two green LEDs will glow.
That happens but the next step, opening WIFI manager on a smart phone does not show any extended network NETGEAR_EXT.
Model: EX6110|AC1200 Dual Band WiFi Range Extender
Message 1 of 2
Accepted Solutions
Guru
Re: EX6110 won't produce extender network NETGEAR_EXT
did you try factory resetting it?
Push and hold reset for 7-15 seconds while its powered on?
Message 2 of 2
All Replies
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1861 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
