- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX6250 Mesh Extender doesn't work after NightHawk app update
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here's a video of how to use the installation assistant. the manual also goes over it.
How to Setup your WiFi Range Extender with NETGEAR Installation Assistant - YouTube
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX6250 Mesh Extender doesn't work after NightHawk app update
Try factory resetting the extender and then set it up using the installation assistant and NOT wps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks @plemans . Can I please check, when you refer to "installation assistant", do you mean the Nighthawk App or something else?
- If it's something else, can you please pass me the URL for it?
- If it's the Nighthawk App, then that's what I'm having trouble with. The Android Nighthawk app closes down everytime i get to "Personalise Settings" during setup, so I'm never able to complete the setup.
Thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since the last update the app no longer functions properly. I like many purchased the Nighthawk to have access to the interface to control users privileges and time in use. Now it doesn't even recognize bandwidths. It would be funny I guess if I was on the otherwise of ownership. Once again per the current update November 17, 2021 the app has stopped functioning again. At least you can count on one feature that is consistent!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, walking through the instructions in this video solved it, thank you!
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
