×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
EX7300
Deaconman
EX7300
I'm trying to setup my Nighthawk X4 Wifi mesh extender using the WPS method. I press the wps button on my extender and my router. 3 green lights come on but the connected light does not come on. My wifi is Charter Spectrum. My nighthawk app cannot find the NETGEAR_EXT network.
The extender is located 3 feet from the router.  What have i missed?  Any suggestions?
Model: EX7300v2|AC2200 Nighthawk X4 WiFi Mesh Extender
Message 1 of 5
Guru
Re: EX7300
What router are you connecting to?
firmware on the extender?
did you try using the installation assistant and not wps?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 5
Deaconman
Re: EX7300
My router is a Charter Spectrum Ultra 400 MG. I have attempted to connect from the Nighthawk app, but when I go to settings to connect to Netgear_EXT network it never appears under my available networks.
I have also tried connecting an ethernet cable from my router to my extender but still no luck. The firmware is the original firmware that was on the extender when I purchases it in July of this year. I have never gotten it to work since I had it.
Do you think that the firmware needs to be updated?
Message 3 of 5
Guru
Re: EX7300
When you connect the router to the extender via hardwired, the extender needs to be in access point mode.
start with this.
Factory reset the extender. push and hold reset for 7-15 seconds while its powered on.
then connect a pc/laptop to the extender via the ethernet port.
disable the wireless on the laptop/pc so the device doesn't connect back to the wireless during setup.
then try setup.
btwn spectrum ultra 400 is a speed plan, not a model. What actual router is it?
Whaty firmware is on the extender?
Message 4 of 5
Deaconman
Re: EX7300
Thanks, The Router is a Sagemcom
Model: SAC2V25
Message 5 of 5
Discussion stats
  • 4 replies
  • 635 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
