×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
EX7700 Extender
CarnegieMark
EX7700 Extender
Hi, I have reset my extender and now cannot connect to my home wifi using the netgear app.
Any advice as to how to fix.
Thanks
Message 1 of 4
Accepted Solutions
Guru
Re: EX7700 Extender
Glad to hear it!
You might mark it solved so others aren't still trying to fix your issue.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 4 of 4
All Replies
Guru
Re: EX7700 Extender
What firmware is on the extender?
What router are you connecting it to?
What method of setup did you use? Wps, the app, or the installation assistant?
Message 2 of 4
CarnegieMark
Re: EX7700 Extender
Hi Plemans,
Thanks for the assistance.
I ended up being able to re-setup the extender and now everything is working ok.
Regards
Message 3 of 4
Guru
Re: EX7700 Extender
Glad to hear it!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 463 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
