- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX7700 as a access point
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
i planned to buy an EX7700. I want to use it as an access point. I want to connect it to my r7500 netgear router by one Ethernet cable and use the other Ethernet connector to connect to my Windows 10 pc on the second floor where I have poor WiFi. I want to place the EX7700 direct near my PC. Will the extender, working as an access point, send a good, fast WiFi signal?
I have a modem from my provider in bridge with my R7500 WiFi router. My WiFi abo is 150 mbps. I now get about 7 Mbps on the 2.4 GHz band and 30 Mbps on the 5 Ghz band .
Near my router I get 140 mbps on the 5 Ghz.
Can someone on this forum help me?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX7700 as a access point
You can connect an EX7700 to your current router and run it in access point mode. You can also connect your wired devices to it.
It'd work pretty well. A good choice in setup.
Its expected for wifi speeds to be faster by the router and drop off with distance. Thats basically how wifi works. Adding in an access point can help with that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for your fast answer. One extra question: suppose the pc gets 140 mbps bij the Ethernet cable from de ex7700, does that mean that it he extender 'sends' also about 140 Mbps?
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes. The benefit to hardwiring in the extender is that it'll be starting at the same speeds.
User | Count |
3 | |
1 | |
1 | |
1 | |
1 |
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
