- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX7700 slow
- Mark as New
- Bookmark
- Subscribe
- Permalink
EX7700 slow
I have installed my ex7700, and have slow wifi in both 5ghz and 2.4
It’s currently less than 2 meters away of my router
Original speed 350Mb+
EX7700 : 40Mb
Why is it slowing down 10x times my network... ?...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX7700 slow
What router are you connecting to?
What firmware is on the extender?
Did you set it up manually or using wps?
What speeds do you get if you hardwire into the extender? (lets us test the backhaul)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX7700 slow
connected to my provider router SFR
firmware 1.0.0.206
Manual setup
i'll do the hardwire test asap
thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX7700 slow
I'm now connected on ethernet to to EX7700. Same slow speed of approx 35Mb..
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX7700 slow
Try hardwiring the EX7700 to the router and try it in access point mode. for testing purposes.
The router could be limiting it with its own qos settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX7700 slow
Ok test done : In access point mode, it's getting the same speed as the original router...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX7700 slow
which means the 3x wireless radios are working as expected for them.
it could be the 5ghz off the router has interference or is using a form of QoS to reduce speeds.
You could also try downgrading the firmware on the EX7700 a version and seeing if it helps.
