- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Extender name WN3000RPV3
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
i have a WM3000RPV3 Extender.
If I want to use my iPad outside then I have to select the _EXT network.
Ideally, I’d like my iPad to automatically switch to the best network.
The recommended solution is for your router and extender to have the same SSID.
Will this work with my model extender?
If yes then is there anything else that I may have to consider.
Do I need to change anything on my iPad ?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Extender name WN3000RPV3
You can set the ssid the same but it won't auto-roam. The ssid would be sticky in that devices will tend to stay connected to the router or extender until they basically loose signal.
You could upgrade to mesh extender that has those capabilities built in.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes. That’s what I found when I set the names the same.
Mesh it is then.
Thanks for your help. Appreciate it.
