× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Extender not connecting X4S 7500
XMalibu101
Initiate
I currently have a MR60 Mesh wifi setup in my house. Needed to extend wifi downstairs but couldn't buy just one extender of the MR60. I was sold a X4s 7500 tri band Mesh extender.
  I cannot get it to 1) connect or extend off my exisitng router and 2) the Nighthawk app doesn't recognise it so can't just "add a device".
At a loss here as device doesn't seem to recognise anything.
Model: EX7500|AC2200 Nighthawk X4S Tri Band WiFi Mesh Extender
Message 1 of 4
Guru
Re: Extender not connecting X4S 7500
it doesn't integrate with the system but you should be able to connect it.
don't use wps for setup since it doesn't fully integrate.
Factory reset the extender and then install it using the installation assistant. Not wps or the app.
Message 2 of 4
XMalibu101
Initiate
Thank you Plemans....works a treat now. CheersSmiley Happy
Message 3 of 4
Guru
Glad it working for you!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 519 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
