× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Facing Login Issue On My New Range Extender Setup ? Can't Connect to mywifiext for New Extender ?
ammie915
Follower
Trying to get my new wifi range extender up an running but as they said its simple plug and play device for me it is real pain from last 1 week. i have tried with the wps in which first i pushed the wps on my extender and then within 2 mins i did the same on my netgear router it blinks for sometime after that ther is nothing.
    I even tried it on my laptop i connected my laptop to my extender's network Netgear_Ext and pulled up my web browser and on address bar i punched mywifiext net it then spins for few seconds then gives you are not connected to your extender's network.
   I have even tried with the deafault ip address still now luck
What should i do ? Where do you think the problem is ?
Its an Nighthawk EX8000 X6S Tri-Band Wifi Mesh Extender
AC3000
Model: EX7000|AC1900 Nighthawk WiFi Range Extender, EX8000|AC3000 Nighthawk X6S Tri Band WiFi Mesh Extender
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 415 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
