- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Mesh Extender
- Mark as New
- Bookmark
- Subscribe
- Permalink
Mesh Extender
I have non mesh wi-fi set up at home with coaxial internet coming into a modem and a couple of extenders. Needed a third and after unsuccessfully trying to connect it realize i bought a mesh extender. Am i right to think it will not work with my setup?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Mesh Extender
It should work fine. You can disable the mesh aspect of it if you want.
Something I would caution though is the speed hit you'll be taking if you're daisy chaining them.
standard extenders by their very nature cut thoughput (speed) in half. the reason they do this is that they have to send and recieve with the same chips and can't do both at once. this compounds when you add extenders to extenders. So if your 1st extender (at very best) is running 50% of the router speed, the very best the 2nd extender in the chain can expect is 25%. And again, those are if they're getting full speeds anyway. Which they rarely are. Add a 3rd extender and you're at 12.5%.
I'd recommend setting them up in a star configuation:
Star: Extender(50%)<--------router--------->extender (50%)
Extender(50%)
Daisy chain: Router------->extender (50%)--------->extender (25%)-------->extender (12.5%)
I also usually recommend people move to a full mesh system like orbi if they're needing more than 1 extender. They tend to have more stability, better speeds, and just work better.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Mesh Extender
