× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
N300 WiFi Range Extender not working with Windstream
StuartJ12
Follower
Windstream said I needed an extender for computer in basement.  I just got a N300 and followed the installation instructions but the Router Link LED never comes on even if I put the extender in the same room with the router and the new network says I have no internet connection.
Model: WN3000RPv3|N300 WiFi Range Extender
Message 1 of 4
DexterJB
NETGEAR Moderator
Re: N300 WiFi Range Extender not working with Windstream
Hi @StuartJ12,
You will need to go through the setup procedure.
You may check the quick start guide linked below as reference.
http://www.downloads.netgear.com/files/GDC/WN3000RPV3/WN3000RPv3_QSG_17Aug2015.pdf
Dexter
Community Team
Message 2 of 4
Subramanianmca
Hi,
Did you get this problem resolved?
I have the same problem with my wifi extender. Couldn't fix it. Can anyone help to fix this problem?
My router was working fine for 20 days and stopped working after that. There is no special cause I could figure out...
Your help is highly appreciated... Thanks in advance
Subbu
Message 3 of 4
DarrenM
Sr. NETGEAR Moderator
Hello Subramanianmca
Have you tried to factory reset the extender and do the setup again?
DarrenM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 4642 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
