KABL's avatar
KABL
Tutor
Jun 21, 2017
Need to change settings and factory reset is not working
Hi, I have an EX6100 extender. We changed the WEP password on our router and now can’t get throughput on the 6100. When I do a factory reset it doesn’t work--the old network names (for 2G and 5G) still show up, and no matter what I’ve tried there is no throughput, and I can't access the device via Netgear. How do I properly reset and start over? Thanks!!
    • KABL's avatar
      KABL
      Tutor
      Hi, I have the manual and have followed all of the instructions. I have reset several times, I have "forgotten" the old networks, etc. nothing is working.
      • netwrks's avatar
        netwrks
        Master
        Did you change the SSID names and a factory reset isn't clearing it? Or, do you see the Netgear_ext SSID's?
