× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Nighthawk MK63 - cabling to satellites
STEHAY
Sorry if this has been asked before. If I buy the MK63 system for my home, do I need to run cabling from the new router to the two satellites?
Message 1 of 5
Accepted Solutions
Guru
Re: Nighthawk MK63 - cabling to satellites
You don't need to have it hardwired in. It is an option (and a good one if you want faster speeds) because the hardwired connection takes the backhaul burden off the wireless. But it isn't necessary.
Message 2 of 5
All Replies
Guru
Message 2 of 5
STEHAY
Thank you. So I will cable from my router to the two satellites. However, I would like to cable from my TV directly into satellite #1 but I guess that's not possible as I don't think they have enough ports?
Message 3 of 5
Guru
You can use a cheap 5-8 port switch. They're not expensive. I'd just make sure to get a gigabit one. Usually they're around $20-30
so you'd go
Cable----->switch----->MS60
                    V
                   TV
Message 4 of 5
STEHAY
Thank you very much. That's perfect.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 820 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
