× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
ORBI
warmingr
ORBI
I want to connect a smart power plug that only uses 2.4 GHz.
can I somehow select the 2.4 GHz to use this Smart Plug.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 4
Accepted Solutions
Guru
Re: ORBI
Once its connected it usually doesn't have problems. you can go into advanced-wireless settings  and turn down the 5ghz radio strength. I usually do this for getting device connected and then crank it back up.
Message 2 of 4
All Replies
Guru
Re: ORBI
Message 2 of 4
warmingr
Re: ORBI
Thank you for your assistance.
Problem solved and really easy.
Very much appreciated.
warmingr
Message 3 of 4
Guru
Re: ORBI
Glad to hear it worked so well for you!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1225 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
