Orbi WiFi 7 RBE973
Reply
Problem with Wifi on all Apple Devices on my Network
SAG1
Tutor
I'm trying to determine if my wifi cameras are conecting to my network through the mesh extender howeve when I pulled up the Netgear geeingnie it only shows one of the cameras. Are the others not using the mesh device even though the mesh device is between them and the router? Or are they not being shown but are connected?
By the way, when I checked again, a different camera was listed in the genie.
I just updated the firmware but that didn't help.
Running the genie on a Win 8 tablet.
Model: EX6400|AC1900 WiFi Mesh Extender Essentials Edition
Message 1 of 6
Christian_R
NETGEAR Employee Retired
Re: Problem with Wifi on all Apple Devices on my Network
Hi SAG1,
Please check out page 18 of the user manual: http://www.downloads.netgear.com/files/GDC/EX6400/EX6400_UM_EN.pdf
~Christian
Message 2 of 6
SAG1
Tutor
Thanks for the info Christian, however, I did follow those instructions originally but didn't see all of the devices. That's why I posted this question.
Message 3 of 6
schumaku
Guru
The "running genie on a Win 8 tablet" is a little bit vague. Talking of the Windows desktop Genie App or the devices individual Web UI? Unfortunately the router based Attached Devices and the Device Map on the Genie Apps is a little bit a git and miss.
If you want to check the clients associated with the extender, use the Extender Web UI direct. (either by http://mywifiext.net while connected direct to it, or by the Extender IP address.
Message 4 of 6
SAG1
Tutor
Thanks for the info schumaku
I am using a Win 8 tablet and did go through http://mywifiext.net but I didn't try the Extender IP address yet.
Maybe I'll try that just to see if everything is connecting properly.
Thanks again.
Message 5 of 6
schumaku
Guru
Afraid, that will end on the same extender ... so this won't help for now.
Also check the router via http://routerlogin.net or it's LAN IP (the computers default gateway).
Was under the impression you had used the Genie App, sorry.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1452 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
