Dargy's avatar
Dargy
Suddenly My Wifi Extender Won't Connect To One Device While Others Can
 So the other day i was on my ipad and suddenly the connection cuts out. As i try to reconnect to my wifi extender, it just stopped connecting all together. It will let me reglog /select to connect to the extender but it will not connect ("unable to connect"). I have already tried doing a Factory reset on my extender ,but i still get the same result and am unable to connect to the extender through my ipad. Although other devices that connect to the extender have no issues connecting to the extention and are able to use it. Its beyond me why it just stopped working for my ipad and i am so lost on how to fix it. please if anyone knows how i am able to solve this issue let me know....
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi Dargy
    Have you tried forgetting the network in the iPad settings and connecting to it again?
    Christian
    • Dargy's avatar
      Dargy
      Yes, ive tried doing that many times but still the same result. It loads as if its connecting ,but i get the "no internet connection" text.
      • StephenB's avatar
        Have you tried connecting the iPad to the main router (just to confirm that this is specific to the extender)?
  • Did you find a solution? The same problem is happening with me
    • Dargy's avatar
      Dargy
      No unfortunatly i have not found the solution to this problem yet
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Dargy,
    1. What is the firmware version of the extender?
    2. Have you tried changing the channel of the main wireless router?
    3. Have you tried changing the password for the WiFi of the extender?
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Dargy,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
