fflanders's avatar
fflanders
Unable to connect laptop to N300 EX2700, but can with other devices
I have successuflly setup my N300 EX2700 WiFi Range Extender and updated to Firmware V1.0.1.52
However:
I did so with an ethernet chord connected to the extender, in the same room as the router.
I am able to connect my phone and tablet wirelessly to the extender, but when I attempt to do so with the very same laptop I setup the extender with, I get the error message 'Windows was unable to connect to Network_EXT.' I am also unable to connect to http://www.mywifiext.net/ from my laptop. (Operating System on the laptop is Windows 7.)
Why would this be?
    • fflanders's avatar
      fflanders
      Hi Christian,
      What do you mean by, 'once you are able to get into the extender's UI.' By this, do you mean access the http://www.mywifiext.net/
      page? How do I do the method: Setup>Internet Setup, to ensure that my Internet IP address is set to "Get Dynamically IP Address From Router" is enabled?
      Is this done someplace within the windows OS control panel? Or elsewhere?
      Thanks
      • Christian_R's avatar
        Christian_R
        NETGEAR Employee Retired
        Hi fflanders,
        Correct. Please use http://www.mywifiext.net/ to access the extender's admin page. Once logged into the admin page, please click Setup and then click Internet Setup. After, please click on Get Dynamically IP Address From Router
        ~Christian
