Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WG602v4 No Internet With Time Warner Cable Modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-24
05:36 AM
2013-09-24
05:36 AM
Like many other posts, was working, stopped working. Not knowing how someone else set it up way back when, I reset the WG602 to factory defaults.
Cable modem is fine. I plug in laptop via ethernet cable and I see the outside world. However, when I connect the WG602 and attempt to connect wirelessly, I am not able to get an IP. ipconfig /all reports:
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Dell Wireless 1395 WLAN Mini-Card
Physical Address. . . . . . . . . : 00-22-68-D2-7A-36
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Autoconfiguration IP Address. . . : 192.168.0.120
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . :
DNS Servers . . . . . . . . . . . : 209.18.47.61
I have gone through the usual machinations of powering down and restarting. Any ideas? Many thanks.
Message 1 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-24
12:34 PM
2013-09-24
12:34 PM
Re: WG602v4 No Internet With Time Warner Cable Modem
what is the cable modem model
Message 2 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-24
12:47 PM
2013-09-24
12:47 PM
Ambit U10C018
Message 3 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-24
12:50 PM
2013-09-24
12:50 PM
Ambit U10C018 is basic cable modem with out no NAT so installing WG602 cable modem will not going work
You need a router behind it
Message 4 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-24
01:23 PM
2013-09-24
01:23 PM
Uh, . . . per original post it worked fine until recently.
Message 5 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-24
02:24 PM
2013-09-24
02:24 PM
Static ip private ip PC using gateway ip of ISP and DNS also IP of ISP
Probably will not work
You need gateway cable modem and not just modem or wireless router
Message 6 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-24
02:36 PM
2013-09-24
02:36 PM
My friend's PC had an alternate configuration for her wireless adapter that looked like that. Maybe an IP changed. But I also connected at some point with my laptop and it is set to get IP and DNS automatically. What a mess. When I am there next time I am going to see if a Linksys I have works, but I agree the best solution is a wireless modem supplied by Time Warner. Thanks for your help.
Message 7 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-24
02:40 PM
2013-09-24
02:40 PM
Just install wireless router if you have spare
Message 8 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-25
07:13 AM
2013-09-25
07:13 AM
jmizoguchi wrote: Static ip private ip PC using gateway ip of ISP and DNS also IP of ISP
I am thinking about this some more, and I believe you are correct. Can you give me a bit more detail? I have little networking experience.
Sounds like:
Is that it? Thanks again.
Message 9 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-25
07:30 AM
2013-09-25
07:30 AM
Re: WG602v4 No Internet With Time Warner Cable Modemh p
You can try by setup static ip on wg602 with private ip , setup witelss etc
Connect to cable mode
You might able to get ip from ISP to sigle laptop
Message 10 of 10
Announcements
