Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WNDAP350 disconnects frequently
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-26
04:49 PM
2011-12-26
04:49 PM
Hi guys,
On my company we have two WNDAP350 AP's and we have an issue, we are using MC9090 Symbol handhelds and sometimes the device loose conectivity, I know that is something wrong with the Netgear AP's because I have another linksys and it works great. We bought the Netgear to make a stronger wireless range, but I think right now linksys is working better than Netgear. Do I have to configure something? I already have disabled WMM and Power saving mode, it helps a little but the problem still.
Any help would be appreciated.
Thank you
Thank you
Message 1 of 14
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-26
05:29 PM
2011-12-26
05:29 PM
Re: WNDAP350 disconnects frequently
if you are leaving on N mode on AP devices , enable WMM when WPA2 are used.
I would imagine with symbol they are still on legacy G , would make better to use legacy G ap unit...
have you look at open-mesh?... cool stuff
Message 2 of 14
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-26
06:26 PM
2011-12-26
06:26 PM
I did notice more stability when I flashed my 350s with the firmware upgrade 2.1.2. I use primarily N machines on both radios. There is a b/g selection if it would provide more stability than the g/n. And I have encountered some problems in the past if the access point was set to wide-channel (40 ghz) instead of 20 ghz.
I don't know if you can run WEP with these devices, but I am enjoying pretty good service with this device now.....
Message 3 of 14
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-26
06:34 PM
2011-12-26
06:34 PM
40Mhz is for n devices
Use 20mhz /B&G for wireless G devices
WEP is limited to B&G mode for N router/ Aeccess point
Message 4 of 14
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-27
06:33 AM
2011-12-27
06:33 AM
jmizoguchi wrote: if you are leaving on N mode on AP devices , enable WMM when WPA2 are used.
Hi jmizoguchi, I'm in legacy G and I have enabled WMM cause we are using WPA2 5Ghz and the problem remains...
Message 5 of 14
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-27
06:40 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-27
06:48 AM
2011-12-27
06:48 AM
Nop, Symbol does not support 802.11a, well I think so, I have both activated and Symbol only recognize G.
Message 7 of 14
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-27
06:54 AM
2011-12-27
06:54 AM
Then you are not using 5Ghz,
2.4Ghz is what you are using
With legacy symbols, use wireless AP
Message 8 of 14
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-27
07:10 AM
2011-12-27
07:10 AM
I have changed to 2Ghz and the issue remains... 😞
Message 9 of 14
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-27
07:31 AM
2011-12-27
07:31 AM
Now I'm having frequently lost connection with the WMS...
Message 10 of 14
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-27
09:48 AM
2011-12-27
09:48 AM
Tony, are u running 2.1.2 firmware?
The situation with these access points did improve somewhat with this upgrade. But, I still have an unusual occurence that I see only with this device. Using inSSIDer wireless survey application, I notice that both 2.4 and 5 ghz radios alternately disappear from the survey screen. This is the only device that does that. I am running a WNDR4500 right now and both of those radios remain visible constantly, likewise with the Linksys E4200 before that. But, about every 5 seconds each radio disappears from the screen. I don't know if this behavior may affect your scanners.
Message 11 of 14
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-27
10:12 AM
2011-12-27
10:12 AM
Hi, yep I'm running the latest firmaware version: 2.1.2. My problem is that something my symbol loose conectivity. I made a ping XXX.XXX.XXX.XXX -t and I made 300 pings and at least 1% is lost.
Thank you
Thank you
Message 12 of 14
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-27
10:20 AM
2011-12-27
10:20 AM
WMS?
sorry. I got lost with other thread
disregard on symbols.. it was other thread..
what is the wifi adapter model if this pc.
Message 13 of 14
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-27
10:33 AM
2011-12-27
10:33 AM
tonymurillo45 wrote: Hi, yep I'm running the latest firmaware version: 2.1.2. My problem is that something my symbol loose conectivity. I made a ping XXX.XXX.XXX.XXX -t and I made 300 pings and at least 1% is lost.
Thank you
I'm lost in my mind.. it was rich thread..
If I where you I would get legacy wireless G and test out.
some of the legacy wireless G devices will have hard time working with N Access point and routers
if B&G will have an issues with it then I would get different wireless G router to compare the issues
Message 14 of 14
Announcements
