× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WiFi Range Extender
dalber
WiFi Range Extender
I have a friend that has a structure on his property that is getting sporadic WiFi. He calls it a shed but it is really his man cave. Would an extender help him or would he need something between his house and the man cave? Only electricity is run out to the man cave and he does not want to run Ethernet to it. The structure is about 30 yards from the house.
Message 1 of 4
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: WiFi Range Extender
Hi @dalber,
Powerlines work in pairs. One powerline should be wired to the main router and the other one can be plugged in to the shed. Here is a link to an installation guide of one of the models that also has WiFi.
Dexter
Community Team
Message 4 of 4
All Replies
DexterJB
NETGEAR Moderator
Hi @dalber,
Welcome to the community!
An extender is ideally used in between the router and the location where the dead spot is. If there is an area in between where an extender can be placed then it may work. However, you may consider using a powerline instead. Here is the link for NETGEAR powerlines.
Dexter
Community Team
Message 2 of 4
dalber
Dexter,
Thanks very much for the reply!
It looks like a powerline requires a network cable. Is that so?
Message 3 of 4
DexterJB
NETGEAR Moderator
Hi @dalber,
Dexter
Community Team
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1229 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
