- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
range extender not relaying password for wifi
- Mark as New
- Bookmark
- Subscribe
- Permalink
i have installed the range extender ok, it knows the network name with ext on the end but will not accept the password for the base router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: range extender not relaying password for wifi
I am also having this problem, would really appreciate an answer. The instructions suggest I use the same password as I would use to log into my home WiFi network via my main router, but when I attempted to I was rejected with a "invalid password" message, have entered and re-entered the password correctly numerous times only to be met with the same message time and time again. Disappointed after what was a smooth and easy setup until that point, don't want to have to send this extender back so soon.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try to log back into the extender by going to www.mywifiext.net and then change the password and see if you can connect then.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All.
the range extender picked up the WPS from the router but would not relay the password, I logged in using a cable to the extender and put in the password manually and all now works
