× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
website for range extender login broken
shanman
The website i use to login to the router seems to be corrupted. Everytime i login to the website i cannot access any of the features. If i right click and say open in a new page or window, half of the screen is cutoff and i cannot access or change parameters. I have tried this on 3 different browsers, 2 different computerss. I have rolled back the firmware to 3 different versions and still no change. Has anyone else out there experienced this? is it time for a new range extender?
Model: WN2500RP|Universal Dual Band WiFi Range Extender
Message 1 of 6
DarrenM
Sr. NETGEAR Moderator
Re: website for range extender login broken
Hello Shanman
You may want to do a factory reset on the extender.
DarrenM
Message 2 of 6
shanman
Hi darren
I did do a factory reset and now the range extender will not allow  me to add my networks back onto the range extender. the login website is completly screwed up and does not allow the changing or adding of any parameters at all.
Message 3 of 6
DarrenM
Hello Shanman
Something sounds corrupt in the firmware if the extender is still under warranty I suggest contacting support.
https://www.netgear.com/support/contact.aspx
DarrenM
Message 4 of 6
shanman
Hi DarrenM
its 4 years old so its out of warranty. Is there any other way to replace the firmware on the unit with something else?
Message 5 of 6
DarrenM
Hello Shaman
You could try to load the firmware via TFTP
http://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP?cid=wmt_netgear_or...
DarrenM
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 4099 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
