Orbi WiFi 7 RBE973
Reply
wifi EXTENDER
DKS2
Star
wifi EXTENDER
Hi,
I'm having problems re-activating my extender, after i recently changed router. I have reset my extender. But I can’t access www.mywifiext.net
Model: WN3000RPv3|N300 WiFi Range Extender
Message 1 of 5
Accepted Solutions
Guru
Re: wifi EXTENDER
I'd make sure its truly reset. many only push the button. You need to push and hold for 7-10 seconds while powered on.
Also, the easiest install method is with a hardwired connection. Directly connect to it with an ethernet connection.
What are the led's doing when its failing?
Is it broadcasting wifi in the default settings?
here's the picture walk through of setup.
https://kb.netgear.com/25716/How-do-I-install-the-WN3000RPv3-as-an-Extender
and your support site with troubleshooting, guides, and firmware.
https://www.netgear.com/support/product/WN3000RPv3.aspx
Message 2 of 5
All Replies
Guru
Re: wifi EXTENDER
Message 2 of 5
DKS2
Star
Re: wifi EXTENDER
Dear Plemans,
Thanks so much for your reply.
I'll try your suggestion first thing tomorrow morning and let you know how i go.
Kind regards,
David.
Message 3 of 5
DKS2
Star
Re: wifi EXTENDER
Hi again,
Thanks for your advice.  Looks like all ok now.  It did work with the wireless, although as you say, direct connection with ethernet would have been easier.
It did take me to the netgear genie and i just created a new account / password, etc.
Anyway, seems ok now.  Have got myself a little confused, but your advice has definitely made the difference.
Cheers David
Message 4 of 5
Guru
Re: wifi EXTENDER
Glad to hear you got it up and running again!
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2800 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
