- S'abonner au fil RSS
- Marquer le sujet comme nouveau
- Marquer le sujet comme lu
- Placer ce Sujet en tête de liste pour l'utilisateur actuel
- Marquer
- S'abonner
- Page imprimable
SXR30 issue with the firmware
- Marquer comme nouveau
- Marquer
- S'abonner
- Surligner
- Imprimer
- Signaler un contenu inapproprié
We have an SXR30 system and after the firmware update 4.3.3.106 we can no longer connect to the satellites. They are however visible and - according to Insight - connected (one with a good connection and the other correct) but impossible to access the internet except via the "Guest" which works (slowly).
Is it possible to revert to the old firmware? Before the update, actually everything worked very well...
I have already restarted all the hardware but that doesn't change anything.
In the application that I use to check the wifi it now tells me Wifi 5 whereas before it was Wifi 6.
I see in Insight that clients are connected to the satellites while on another screen it indicates that nothing is connected to the satellites... What can I do to recover wifi that was working correctly?
