× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
N900 not allowing samsung Bluray player to access
R47
My new Samsung Blueray player can see the Wifi and i can input my security code but it won't connect. I've tried everything with samsung support and we can't get it to connect. I haven't had issues with anything else?
Model: R4500|N900 Wireless Dual Band Gigabit Router
Message 1 of 5
Accepted Solutions
JamesGL
Master
Re: N900 not allowing samsung Bluray player to access
Hi R47,
Check the security option that BluRay supports. Lower down the security option of BluRay does not support WPA2.
Message 4 of 5
All Replies
These things usually come down to the settings on the BluRay player. These "smart" devices are actually very dim. You might do better to find a forum where people talk about Samsung's BluRay players.
I had hell's own trouble getting my Samsung BD-F6500 to work over wifi. Fortunately, I had already decided to go down the Powerline Ethernet route and now use the LAN feature.
Message 2 of 5
R47
Thanks for the response. I went through the aettings with the Samsung support guy. I'm thinking it's something with the router
Message 3 of 5
JamesGL
Master
Hi R47,
Message 4 of 5
JamesGL
Master
Hi R47,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1182 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
