Attached Devices
5 TopicsSorted "Attached Devices" for Orbi
Within the Orbi's web admin interface, the ability to sort the attached device list is conspicuously missing, yet very helpful for seeing what is going on at a glance. Most routers have this capacity. Essential user parameters would be to sort by IP address, connection type, or "connected orbi" i.e. sorted list of what's connected to the router, and each of the satellites, with the fixed listing being by IP address.13KViews35likes11Commentsattached devices shows devices that are physically wired as connected via wireless
Having issues with network "thrashing". General: I put in Orbi a few months back. Continuosly troubleshooting things that I can't quite figure out if I'm having multiple device issues or an Orbi issue. The satellite has already been replaced. Problem: One specific issue I see is that I have a server that is wired directly to Orbi. When looking at attached devices it shows as "2.4Ghz Guest". Wireless is turned off at the server and I don't even have the "Guest" network enabled. If I reboot Orbi it will show "wired" for a few seconds then switch to 2.4Ghz Guest. Once I can figure this out I want to try and determine why some devices show "2.4Ghz guest" vs "2.4Ghz".R8900 - Ever since last firmware, can't rename devices in connected device screen
Ever since the firmware update that went out within the last week, it won't allow renaming of devices anymore. In admin screen --> Attached Devices --> (click on any device icon) --> (enter a new name and hit apply) == the following.... 400 Bad Request This server does not support the operation requested by your client. This happens for any device attempted.Solved2KViews0likes3Comments
