Backup
84 TopicsReadyNAS internal Backup cannot create certain directories
Ready NAS 214 Firmware 6.10.10 Dear Community, I´ve got a problem during internal backup to a connected USB-Hardware-Drive. I save about 1500 files without any problem, but then I´ve got some files the system is not able to copy. The error message in the protocol is: "Cannot create directory XXX/XXX 2023/GA 3611 - 23 VU XXXX !" I`ve got a lot of these kind of files wich are all copied completley without any trouble. But 9 files have the problem and I don´t understand what it is. I`ve already checked if the name of the file is different to others, but I can´t see any problem. Maybe somebody facing the same issue and can help me how it was resolved. Kind regards855Views0likes4CommentsRemote access error for Backup Job
I'm having a problem with backups on my ReadyNas Duo v1. I've just reinstalled my Windows 10 Home PC and I am now getting "Remote access error for Backup Job". I've been trying various ways to get this going for a couple of days now, some of the things I've tried are: Share I am trying to get to has full access granted to my Microsoft account, a local windows account and Everyone. Accessing the share from another PC using the Microsoft account and the local windows account I have tried entering my Microsoft account the local windows account and nothing the login and password fields SMB 1.0/CIFS client and server are both on, automatic removal is off Firewall on and off. Updating ReadyNas Frontview firmware to 4.1.16 When I try Test connection I get an "error connecting" message, if I put //PCName in the host I get successfully connected but I still get the remote access error I am now out of ideas so if anyone can help it would be very appreciated. Thanks Pete3.2KViews0likes17CommentsFTP Backup error
Firmware 6.9.2 Occasionally, FTP scheduled backup fails with the errors below. We scheduled the exact FTP backup activities with another client, and everything works: only the ReadyNAS fails. -------- Backup Job Information -------- Backup Job Name: XXX Backup Job Type: Full Protocol: ftp Backup Source: [remote:ftp]/ftp://xxxx Backup Destination: xxx Backup Start Time: Wed Feb 7 2018 15:05:02 Backup Finish Time: Wed Feb 7 2018 15:09:18 Backup Status: Fail: Connection cannot be established. Check the connection and authentication, if required.2.2KViews0likes10CommentsMigrating gracefully from ReadyNAS OS4 to OS 6 (Settings, Data)
I have a ReadyNAS Ultra 4 running RAIDiator 4.2.31 , and I am looking to move to a ReadyNAS OS 6 device as gracefully as possible. My current NAS is not damaged or dead, so no emergencies - I just want to minimize the amount of work I need to do to make the move happen. My current plan is to back up all the data onto an external drive, move the drives to the new chassis (which will wipe them), and then restore the data. So far, this part is fine. My question comes down to the settings - if I back up the settings on RAIDiator 4.2.31 (IP, Shares, Users & Security, etc.), can I restore them onto to OS 6 device? Is there another graceful way of migrating all my settings, so that I do not need to re-create them all by hand and reset permissions? Thank you!1.2KViews0likes2CommentsREadyNAS RN21400 with OS 6 Dropbox Authorization hangs
Cannot turn on Dropbox. I'm attempting to set up a Dropbox sync with our RN21400 ReadyNAS for backups. After going to admin page and going to the cloud tab, I'm trying to enable "Sync with Dropbox" but after switching this from "off" to "on" a pop-up redirect page for Dropbox authorization appears and just hangs. this happens with Chrome and Internet Explorer. I have also tried a different computer. I also to add the Google public DNS 8.8.8.8 as primary as well just in case.2.8KViews0likes10CommentsUSB HDD used as destination for Backup of 314 / use old NAS instead?
I purchased a Seagate Expansion 3TB Desktop External Hard Drive USB 3.0 (STBV3000100) few years back to serve as my destination to backup my RN314. I plugged it into the front port of my NAS and while I am able to back up to it, it only recognizes 2 TB of space. 1. Have I done something that limited my NAS to recognizing only 2TB. 2. Assuming I fix that, or the NAS OS is capable of larger destination drives, what is maximum supported? I currently only back up with shares and not my timemachine (a decision made mainly about space). I recently began a vertical upgrade of space on my NAS, because my Shares grew. I am now backup up only 3 of 4 shares. The data on the 4th is replaceable with a little effort. As an asude, I still have the chassis of my old ReadyNAS NV+ can I fill it with retired HDD from my upgrade and use it as a backup destination? EIther place it offsite and backup over the net (might be too slow) or bring it onsite once a week and store it off site?SolvedReadyNAS - Multiple Azure Backups with different versions?
Hi all, I'm running a ReadyNAS 100 series with 6.9.1 firmware The end result I am trying to achieve is having the shares on the NAS backed up to Azure with multiple versions so I can recover a file if it is deleted accidently. If a file is accidently deleted from the NAS I want to be able to flick over the Azure and recover the file, currently it looks like it is doing a 1:1 sync which means an accidental deletion is not recoverable in Azure. How can I get this going as the Synology I have allows me to use HyperBackup to backup at certain times directly to a third party cloud provider with versioning - hopefully there is something close to this on a Netgear. Any help/advice is greatly appreciated Thanks Adam1.6KViews0likes2CommentsBacking up a 1TB RNDU4000 to Cloud, what cloud ?
Im confused about the Netgear cloud functions. For a RNU4000 with firmware 4.2.31 What cloud backup can I use ? I need 1 TB storage. Does Netgear have a solution for this or should I look for others? Will my NAS support other cloud backup solutions ?1.5KViews0likes5CommentsBackup GSM7224 L2
Hi. I have a GSM7224 and wish to backup via a command line as there is no GUI. Does anyone know the said command to backup the current config. I have a TFTP server already i thought something like copy startup-config tftp 192.168.1.1 tftp\config.cfg. But cannot seem to get any command correctSolved1.7KViews0likes1Commentbackups from pc failing after upgrade
after installing the upgrade 6.9.0 my backups from my PC no longer work the backups ( 15 of them ) all start and remain in the " in progress" state. in previous version they remained in the " in queue" state until next one could be actioned - now they all go to in progress straight away but dont do anything. on testing the source, I find that it is reporting invalid user name or password. my PC access is not protected by user name or password and in the previous version there was no problem with access of the PC with these fields left blank. the only thing that has changed is the update to 6.9.0. please advise... I have no backups running now since the upgrade to 6.9.0.Solved14KViews1like34Comments
