Insight AP
51 TopicsSet up mesh on WAX 628 without need for insight subscription
Feature request On wax 628 after 4 year subscription ends we should be able to amend mesh mode as currently it can only be done via insight. So after 4 years if you had to factory set the ap for what ever reason what you are saying is i have to pay subscription fee to have access to a basic setting which should be accessible regardless because this setting is a bare necessity for having multiple ap's and the main reason to have bought these pieces of equipment. You should not be held ransom for access to this basic necessity. This feature should be added to the next firmware update like for example accessing it via device ip address configurations Currently to be able to mesh multiple ap's you have to go to mesh topology on the insight app to change mesh mode to auto, root , extender or disable. After 4 years if this stays the same I have to subscribe per unit to be able to have access to this basic setting which is utterly ridiculous if you think about it. If you were to factory reset or for whatever reason need to change the mesh mode you couldn't without ponying up. So after 4 years my equipment is redundant because it wouldn't serve me the purpose for which they were bought for. So this should be added and available to access in the device IP access configuration page via local network98Views0likes1CommentSyslog WAX(618) - empty hostname field causes issues
I noticed when sending syslog from the WAX's to our syslog server (in this case a Wazuh SIEM installation) that there's some issues. First issue, it's hard to differentiate the syslog coming from the access points with syslog coming from other devices if there's no name in the logs. And second, the predecoding in this syslog server now interprets the program name (app name) as the hostname and as there are many processes running on the device this 'pollutes' the hostname field in the opensearch database with lots of processes (non existing hosts). There have been other reports of other syslog sending devices causing issues with this syslog decoder, so the issue is not Netgear exclusive (and I have been able to find a common regex to differentiate), but it seems that adding a name in the logs would not be so hard to do and it would probably fix both issues and it would be convenient. (Our M4300 stack does have a hostname in the logs and I think it's a good thing to be consequent) While this field can be left empty according to the standard it also says that an empty value is very unlikely (RFC5424). https://www.rfc-editor.org/rfc/rfc3164#section-5.2 https://www.rfc-editor.org/rfc/rfc5424#section-6.2.4 Maybe include the 'location' name which is shown in Insight as the hostname?216Views1like8CommentsWAX615 night mode
Currently, only the "default", "off" and "off except power LED" settings are available. I have 3 WAX615s at home and one is on the bedroom floor; the blinking LED lights are really annoying at night. Is it possible to consider to develop a feature that can be enabled to automatically turn off the lights during specific hours?43Views0likes0CommentsInsight Captive Portal (Free)
You have added a much-improved Captive Portal option to Insight, but have failed to provide any option to retrieve the collected data, i.e. name, email, etc. I spent the time and went through and set it up only to subsequently spend hours trawling through the whole portal in detail and ultimately contacting support to discover that this "may be an option in a future release", which makes the whole thing pointless and a waste of time. I suggest that you at least make a note on the portal to state that the feature is incomplete, although it would be far preferable to provide access to the data collected!55Views2likes0CommentsWBE758 onboarding Engage - Give us the ability to hide/not broadcast SSIDs
Went to go onboard a WBE758 to Netgear Engage, everything went great until I ran into the fact that there is no way to turn off "Broadcast SSID" or "Hide SSID". When you go to the web GUI for that AP, the first thing it says to you is "Items greyed out are managed by Engage", which makes sense, except for features that aren't even on Engage yet. Please add the ability to hid SSIDs on engage with supported Netgear Pro Access Points.646Views0likes3CommentsAllow to rename Clients
It would be immensely helpful to be able to add/edit names of client devices. It would be heck of a lot easy to figure out what each device is... Should be whatever system gets by default and then allowing user to edit, so I can name something like "Printer by Coffee machine"5.1KViews28likes8CommentsInsight Managed WiFi 7 Tri-band Access Point (WBE750) Web UI Configuration
Hi, I've been testing WBE750 for a couple of weeks and a bit disappointed by the lack of WebUI Configuration options. Would it be possible to add 1. A way to change the default port for HTTPS (from 443 to another port) 2. A way to change / update SSL certificate (ideally with a way to retrieve the certificate using acme or from a local repository) Best regards875Views0likes1CommentIdea: Social Services Status Check Platform
Create a comprehensive social services SASSA status check platform similar to SASSA status check, which helps individuals easily track the status of various social service applications and benefits in one centralized place. This could include unemployment benefits, housing assistance, healthcare subsidies, and more. Features: Multi-Agency Integration: Partner with various government and non-profit agencies to provide real-time updates on application statuses. User Dashboard: A user-friendly dashboard where individuals can see the status of their applications across different services. Notification System: Automated notifications via email, SMS, or app alerts to inform users of status changes, deadlines, and required actions. Document Management: Securely upload and store necessary documents, with reminders for expiration and renewals. Support and Resources: Access to FAQs, guides, and customer support to assist with application processes and troubleshooting. Mobile App: A mobile application for on-the-go access to status updates and notifications. Data Security: Implement robust security measures to protect user data and ensure compliance with relevant regulations. Benefits: Convenience: Users can check the status of multiple applications in one place. Efficiency: Reduces the need for individuals to contact multiple agencies for updates. Transparency: Provides clear and timely information on application progress. Accessibility: Mobile app ensures users can access information anywhere, anytime. Business Model: Freemium Model: Basic services for free with premium features available for a subscription fee. Government Partnerships: Partner with government agencies to offer the service as part of their digital transformation initiatives. Advertisements: Display relevant, non-intrusive ads for additional revenue. Implementation Plan: Market Research: Identify the most needed social services and target user base. Partnerships: Establish collaborations with government and non-profit organizations. Platform Development: Build a secure, scalable, and user-friendly platform. Beta Testing: Launch a beta version to gather user feedback and make necessary improvements. Marketing and Outreach: Promote the platform through digital marketing, social media, and partnerships with community organizations. This platform can significantly streamline the process for individuals applying for social services, making it easier to manage their applications and receive the benefits they need promptly. Connection to SOHO Ethernet Unmanaged (FS308): A reliable network infrastructure is crucial for the seamless operation of the Social Services Status Check Platform. The SOHO Ethernet Unmanaged Switch (FS308) by Netgear is an ideal solution to ensure uninterrupted connectivity and high-speed data transfer for this platform. With the FS308, you can: Ensure Network Stability: The FS308 provides stable and consistent network performance, which is essential for accessing real-time updates and maintaining user satisfaction. Easy Setup: Its plug-and-play design allows for quick and hassle-free integration into your existing network, minimizing downtime during deployment. Cost-Effective: An unmanaged switch like the FS308 is a budget-friendly option that doesn't compromise on performance, making it suitable for startups and non-profit organizations. By utilizing the SOHO Ethernet Unmanaged Switch (FS308), the Social Services Status Check Platform can offer a reliable and efficient service to its users, ensuring they can access vital information without delays or disruptions. This enhances the overall user experience and supports the platform's mission to streamline social service applications.1.8KViews0likes1Comment
