Parental Controls
25 TopicsR7000 Filtering Levels Not Working
Just updated our router firmware to V1.0.9.26 on February 23, 2018. Now the filtering levels do not stay set on each device. Some stick and others go back to 'default level on router'. OpenDNS set to moderate, yet can surf anywhere on internet...anywhere! Help. Didn't have this issue prior to update.SolvedParental Controls - Checking Router Firmware
I'm trying to use parental controls on my router. I'm confused because I can still access xvideos on my child's tablet, but the entry shows up as netflix? [Site allowed: 45.57.38.146] from source 192.168.1.5, Monday, Nov 13,2017 11:24:31 [Site allowed: api-global.netflix.com] from source 192.168.1.5, Monday, Nov 13,2017 11:24: Thanks in advance for advice.2KViews0likes3CommentsNightHawk R6900 Circle app not recognizing
Hello, I activated Circle parental control on R6900 nighthawk router and all was working well. However, now via Android Circle app, i can not connect to manage Circle devices nor does the app recognize I have circle active on my router. Anyone have any idea how to proceed? Thanks1.6KViews0likes2CommentsParental Controls: Blocking device based on time schedule
There are multiple inactive community discussions dating back several years with people asking for the ability to set time schedules for individual devices (using MAC addresses or whatever). For example, I want to turn off wifi to my kid's device at a certain time of evening on a school night, but not affect all devices. I may want to have a different time schedule for a younger child than an older child. I may want to limit access to wifi at different times of the day. There should be clear, straight-forward solutions to these issues. Here is a response from Netgear from back in 2015: "Re: Blocking device based on time schedule NETGEAR is working to implement the feature in the near future. You may check the updated FAQs. http://kb.netgear.com/app/answers/detail/a_id/24580/~/c3000%2Fc3700-faqs Regards, JamesGL Community Team" Why is this so difficult? Why doesn't Netgear answer this request after so many years?? This should be at the top of the list of any parental feature offered!!2KViews4likes1CommentCircle Parental Controls Cause Latency
After turning on Circle Parental Controls my latency increased from 10-20ms to 700-1100ms. Is this a known issue? Can we add gaming consoles to a section that bypasses Circle as to not intruduce the latency. Circle is unusable due to this issue.1.2KViews0likes1Commentnetgear Genie Software PW Access
So let's say I want to remove the filters from Network Genie to unprotect my computer. All I need to do is open the app, then click disable parental controls. BRILLANT DESIGN!! That means the computer is unprotected at the click of a button! Any suggestions to get around the flawed design? Basically I want to ensure that the Disable Parental Controls cannot be selected. It would seem that requiring a password would have made sense. I find the only way to do this is to install the software on another computer?2.9KViews0likes1CommentParental Controls - Checking Router Firmware
Hi We have bought a Nighthawk R7000 specifically for the Parental Controls feature. This is for a business who wish to block users from accessing certain websites during business hours. But, 2 users may access certain blocked sites at any time. We checked the router is using the latest firmware. We've created the OpenDNS Account and we can log on to their website OK. The router is using their DNS Servers (208.67.222.222 and 208.67.220.220) We've set up Time Blocks and we can set Whitelists. But, the Whitelist doesn't work. If we Whitelist www.linkedin.com, for instance, it works for a day or so, then blocks everyone. So we decided that a Bypass Account would do the job. This was set up within the OpenDNS web page. For this to work we need to use NetGear Genie (Downloaded for Windows from http://www.netgear.com/lpc) to browse the web, logging on to the Router with the bypass Account. This is where it goes horribly wrong. We can open Netgear Genie on the PC, but if we click the Parental Controls tab we get a message "Checking Router Firmware We're making sure you have firmware that supports Live Parental Controls. It looks like you might not be connecting to the internet through a supported NETGEAR router........." Does anyone have any suggestions as to how we may overcome this issue? Many thanks Michael DSolved13KViews0likes28CommentsR4500 Parental Controls Not Blocking - Help My Kids Are Exposed
HELP PLEASE. Just unpacked my brand new NetGear N900 R4500 FW V1.0.0.4_1.0.3. Purchased from Amazon last week, Works great, but can't get parental controls to work. NetGenie and Genie App, both indicated Parental Controls enabled at High, but nothing gets blocked. Tried checking and changing the DNS figures, as mentioned in this community, but nothing works. Also tried reseting and checking for firmware updates, but same result. Tried starting from scratch plus I tried checking my OpenDNS account online, but still doesn't work. All settings on high, but nothing gets blocked. I am open to other ideas. I hope I won't regret this purchase. Thanks! Jedimindtrick3.4KViews0likes3CommentsNetgear Genie not connecting to open DNS for parental controls on Android or Windows 8
Hi everyone. I am not the most tech savvy person, but I am learning. I have a very resourceful 15 year old I am desperately trying to protect from various websites and this issue is driving me crazy as it seems to be exactly what I'm looking for but simply not working. I have an Open DNS account I created online, I have certain sites blocked through that accunt oline which is connected to my Netgear. But I can type them in and visit them from any device connected to the internet via this router. When I try to login in to the Open DNS, I get this an error message saying to verify that I'm connected to the internet and try again. I am obviously connected to the internet as I'm online posting to this forum. Is anyone else experiencing this? How was it resolved? Please help!!!! Thanks in advance.4.8KViews0likes1Comment
