Public ReadyNAS OS 6.x Beta
18 TopicsNeed help: System volume root's usage is 100%
Dear community, I have serious issue with my ReadyNAS 102. Currenrly my ROOT volume usage is 100%, resulting in not being able to access the Frontview and all kind of instabilty in the accessibility of my shared locations and installed apps. Also my MEDIA volume has less than 5% capacity resulting in instability issues. Who can help and support me in getting this issue solved? Find enclosed my logs: Filesystem Size Used Avail Use% Mounted on udev 10M 4.0K 10M 1% /dev /dev/md0 4.0G 2.4G 1.4G 65% / tmpfs 249M 0 249M 0% /dev/shm tmpfs 249M 528K 248M 1% /run tmpfs 125M 0 125M 0% /run/lock tmpfs 249M 0 249M 0% /sys/fs/cgroup /dev/md127 462G 245G 216G 54% /Storage_2 /dev/md126 927G 762G 140G 85% /data /dev/md126 927G 762G 140G 85% /apps /dev/md126 927G 762G 140G 85% /home /dev/md127 462G 245G 216G 54% /run/nfs4/Storage_2/Documenten_2 /dev/md127 462G 245G 216G 54% /run/nfs4/Storage_2/Movies_2 /dev/md126 927G 762G 140G 85% /run/nfs4/data/Music /dev/md127 462G 245G 216G 54% /run/nfs4/Storage_2/Music_2 /dev/md126 927G 762G 140G 85% /run/nfs4/data/Pictures /dev/md127 462G 245G 216G 54% /run/nfs4/Storage_2/Shows_2 /dev/md126 927G 762G 140G 85% /run/nfs4/data/Transmission /dev/md126 927G 762G 140G 85% /run/nfs4/data/Videos udev 63155 392 62763 1% /dev /dev/md0 65536 65536 0 100% / tmpfs 63590 1 63589 1% /dev/shm tmpfs 63590 542 63048 1% /run tmpfs 63590 3 63587 1% /run/lock tmpfs 63590 9 63581 1% /sys/fs/cgroup /dev/md127 0 0 0 - /Storage_2 /dev/md126 0 0 0 - /data /dev/md126 0 0 0 - /apps /dev/md126 0 0 0 - /home /dev/md127 0 0 0 - /run/nfs4/Storage_2/Documenten_2 /dev/md127 0 0 0 - /run/nfs4/Storage_2/Movies_2 /dev/md126 0 0 0 - /run/nfs4/data/Music /dev/md127 0 0 0 - /run/nfs4/Storage_2/Music_2 /dev/md126 0 0 0 - /run/nfs4/data/Pictures /dev/md127 0 0 0 - /run/nfs4/Storage_2/Shows_2 /dev/md126 0 0 0 - /run/nfs4/data/Transmission /dev/md126 0 0 0 - /run/nfs4/data/Videos 4.0K /var/agentx 64M /var/backups 625M /var/cache 27M /var/cores 4.0K /var/ftp 210M /var/lib 4.0K /var/local 792K /var/lock 69M /var/log 4.0K /var/mail 11M /var/netatalk 4.0K /var/opt 12K /var/readydrop 2.0M /var/readynasd 0 /var/run 20K /var/spool 4.0K /var/tmp 8.0K /var/www 1005M total Any help is welcome! Cheers, Fremske3.2KViews0likes1CommentGroup "users" permissions taking preference over user outside the group (SMB)
Hi, it seems that since 6.5 (I noticed it in 6.5.1, so not sure when the bug started), user/group permissions are completely scrambled. Can you look at my detailed thread here, maybe I should have posted it in this forum to get attention: https://community.netgear.com/t5/Using-your-ReadyNAS/User-and-group-broken-permissions/m-p/1107451/highlight/true#M111893 It details the issue and a few suggestions to the GUI to make things more consistent The issue seems also to be reported here, in less details and over MAC https://community.netgear.com/t5/Using-your-ReadyNAS/Group-permissions-taking-preference-over-user/m-p/1092604#M1101602.4KViews0likes1Commenthow to update to OS6? Is it possible?
Netgear sent me an email recommending upgrading, said: The Vulnerability: NETGEAR has become aware of the Badlock security vulnerability that causes ReadyNAS OS 6 devices to be susceptible to man-in-the-middle (MiTM), denial of service (DoS), and similar attacks. Our records indicate that your NETGEAR product is affected. What You Can Do: NETGEAR strongly recommends that you install firmware version 6.5.0 that was released on May 17, 2016. I stil have RAIDAR 4.3.8 and firmware 4.2.28 and running x86. Not sure what to download and install, any help would be greatly Appreciated.5.3KViews0likes11CommentsDLNA Continues to drop out RN104/6.4.2
Hi, I have a fully wired LAN. Running Firmware 6.4.2 It seems that every time a new update is about to be launched, my DLNA starts dropping out. I'll be sitting watching regualr TV and I'll keep getting messages popping up telling me the ReadyNas has connected to the LAN - like a new device hjas been added/PnP. And/or, if I'm streaming a move from the ReadyNas, it will suddenly stop playing and a hop over to the regular TV. I have to change TV input, browse to the folder and start the movie again. Normally, If I stop a movie at any part, I have the option to 'jump' back to it. When the ReadyNas drops out, I don't have this option It is very annoying. I also recently found the ReadyNas very, very slow. It wanted to build a FAT/Index everytime I looked for files - took ages. I have installed SMB plus and disabled the antivirus - this is what I found when I googled the problem - it seems to have helped the speed issue.2.7KViews0likes2CommentsRsync not working with restricting security options in 6.4.1
After updating to Readynas OS 6.41 my rsync backups over SSH with KEY to another server do no longer work. The remote server has this option in /root/.ssh/authorized_keys command="/usr/local/bin/rrsync /mnt/disk/",no-pty,no-agent-forwarding,no-port-forwarding,no-user-rc,no-X11-forwarding ssh-rsa READYNAS PUCLIC KEYHERE The readynas did to backups to this system without problems... until i moved to 4.6.1 (from 6.2.5). It works if I: A) Either put this in /root/.ssh/authorized_keys on the remote server: command="/usr/local/bin/rrsync /mnt/disk/" ssh-rsa READYNAS PUCLIC KEYHERE B) Or if I issues this command from the CLI on the readynas (ssh login to NAS): rsync -avlz -e "ssh -o StrictHostKeyChecking=no -o UserKnownHostsFile=/dev/null" --stats --progress --exclude 'home_dieter/snapshot' /data/home_personx 10.0.0.xx:/ My conclusion: the 6.4.1 does add some command to the Rsync over SSH that failes to work with a security restricted Rsync server. It's NOT that the Rsync does not work together in terms of incompatible Rsync protocol versions, as far as I can tell. Can someone perhaps tell me what Rsync options the 6.4.1 uses with Rsync over SSH? What has changed with 6.4.1 compared to 6.2.5? info: My NAS: readynas 102, backup server: Debian “jessie”3KViews0likes1CommentSnapshot use place on RN316 but no snapshot in timeline
Hello, I have a space problem on my RN316 (FW 6.4.1). I have no snpashot in timeline but i see snapshot use a lots of space on my RN316. Some manipluation to delete them and get back my disk space ? Can someone help me ? Thanks a lot.Solved5.6KViews0likes9CommentsUSB HDD problems - linked to recent FW6.4.0 upgrade?
I have a RN102 - 2x 2TB discs. In the past few days I have had trouble with my backups to sever USB hdds - several as I swap them trying to resolve the issue. I am not at the point where the RN102 usually will not boot right when a USB hdd is attached, and if I do get it up, backup jobs (RSYNC) fail witrh timeout errors. I am seeing lost of things in dmesg that indicate a USB problem, but I am not an expert to know exactly what: [ 172.121896] xhci_hcd 0000:02:00.0: @000000001f630700 00000000 00000000 0c000000 01078001 [ 172.121904] xhci_hcd 0000:02:00.0: ERROR Transfer event for disabled endpoint or incorrect stream ring [ 172.121914] xhci_hcd 0000:02:00.0: @000000001f630710 00000000 00000000 0c000000 01078001 [ 172.121923] xhci_hcd 0000:02:00.0: ERROR Transfer event for disabled endpoint or incorrect stream ring [ 172.121933] xhci_hcd 0000:02:00.0: @000000001f630720 00000000 00000000 0c000000 01078001 [ 172.121958] sd 3:0:0:0: [sda] tag#26 uas_eh_abort_handler 0 uas-tag 27 inflight: CMD IN [ 172.121970] sd 3:0:0:0: [sda] tag#26 CDB: Read(10) 28 00 00 02 ef 18 00 00 08 00 [ 172.122007] xhci_hcd 0000:02:00.0: ERROR Transfer event for disabled endpoint or incorrect stream ring [ 172.122019] xhci_hcd 0000:02:00.0: @000000001f630740 00000000 00000000 0c000000 01078001 [ 172.122028] xhci_hcd 0000:02:00.0: ERROR Transfer event for disabled endpoint or incorrect stream ring [ 172.122038] xhci_hcd 0000:02:00.0: @000000001f630750 00000000 00000000 0c000000 01078001 [ 172.122046] xhci_hcd 0000:02:00.0: ERROR Transfer event for disabled endpoint or incorrect stream ring [ 172.122056] xhci_hcd 0000:02:00.0: @000000001f630760 00000000 00000000 0c000000 01078001 [ 172.122082] sd 3:0:0:0: [sda] tag#27 uas_eh_abort_handler 0 uas-tag 28 inflight: CMD IN [ 172.122095] sd 3:0:0:0: [sda] tag#27 CDB: Read(10) 28 00 00 02 ef 20 00 00 08 00 [ 172.122132] xhci_hcd 0000:02:00.0: ERROR Transfer event for disabled endpoint or incorrect stream ring [ 172.122144] xhci_hcd 0000:02:00.0: @000000001f630780 00000000 00000000 0c000000 01078001 [ 172.122153] xhci_hcd 0000:02:00.0: ERROR Transfer event for disabled endpoint or incorrect stream ring [ 172.122163] xhci_hcd 0000:02:00.0: @000000001f630790 00000000 00000000 0c000000 01078001 [ 172.122189] sd 3:0:0:0: [sda] tag#28 uas_eh_abort_handler 0 uas-tag 29 inflight: CMD IN [ 172.122201] sd 3:0:0:0: [sda] tag#28 CDB: Read(10) 28 00 00 02 ef 28 00 00 08 00 [ 172.122238] xhci_hcd 0000:02:00.0: ERROR Transfer event for disabled endpoint or incorrect stream ring [ 172.122250] xhci_hcd 0000:02:00.0: @000000001f6307b0 00000000 00000000 0c000000 01078001 [ 172.122275] sd 3:0:0:0: [sda] tag#29 uas_eh_abort_handler 0 uas-tag 30 inflight: CMD IN [ 172.122288] sd 3:0:0:0: [sda] tag#29 CDB: Read(10) 28 00 00 02 ef 30 00 00 08 00 [ 172.122367] scsi host3: uas_eh_bus_reset_handler start [ 172.240448] usb 3-2: reset SuperSpeed USB device number 2 using xhci_hcd [ 172.263248] scsi host3: uas_eh_bus_reset_handler success [ 172.625611] usb 3-2: stat urb: status -71 [ 172.629265] xhci_hcd 0000:02:00.0: ERROR Unknown event condition 199, HC probably busted So, what might my problem be: a. Something up with FW6.4.0? b. I own lots of faulty USB hdds (I am checking them with Seatools to be sure)? c. The RN102 is faulty? d. Something else? Any help would be appreciated. IanSolved11KViews0likes11CommentsAccessing certain files on an SMB share causes that volume to become inaccessible.
Anyone else having problems accessing files via an SMB share on a mac computer? It works fine for a certain period of time, then stops working and causes the box to completely lock up. It's also completely random. For a while it will simply cause the volumes to drop on the mac computer but if you try it too many times it simply crashes the box. I'm getting it on both of my boxes (pro 6 and ultra 6 running beta 2) One drive has SMR drives and the other has WD green drives.2.3KViews0likes0CommentsRaidar 6.0 Windows
I downloaded Raidar 6.0 on my Windows 7 SP1 64 bit system with ReadyNAS 102. Raidar 4.3.8 is running fine, but when clicking on the 6.0 download, presumably to have it installed, I get error message : "The JVM could not be started. The maximum heap size (-XMX) might be too large". What about that? Should I install Java (currently not on my machine) first? Or?Solved5.4KViews0likes4Comments
