R6400
18 TopicsLatest frimware for R6400 V1.0.1.34_1.0.24
After installing latest firmware (V1.0.1.34_1.0.24) on Jan 13, I am no longer able to access readyshare via USB 3.0. It was previosuly intermittent until the last firmware update remedied that issue. Win10 Pro x64 V1709 Any insights would be appreciated. ThanksSolvedR6400 router slow after firmware update V1.0.1.32_1.0.23
WiFi web download speed test dropped from near 100 Mbps download to around 20 Mbps after firmware upgrade. I tested by plugging directly into modem and get around 200 Mbps; same when cabled directly into the router. I see this speed reduction across several computers and phones, so I am sure it is the router and WiFi specifically. I rebooted several times, unplugged and replugged, check that WMM and QoS remain disabled, no blocking is enabled. My Macbook Pro connects over 5G on channel 157. Please advise on what to do next. Otherwise I'm moving to away from NetGear...Solved6.6KViews0likes8CommentsR6400 wired connection drops out briefly every half hour or so (wireless never does)
Hello all. This is regarding my R6400 WiFi Router with the most recent firmware (V1.0.1.34_1.0.24). For a long time now my ethernet cable connection from Router to desktop PC (windows 10 64) has disconnected briefely every half hour or so (sometimes more sometimes less it's hard to gauge). I would say it goes out for about 10 seconds then returns. I see a little red X over the internet symbol in the taskbar when this happens so it's definitely going down for whatever reason. It's not the worst problem one can have, but sometimes I play online poker and it can make a huge difference there when in a big pot happening. I really can't risk it anymore and need to solve this. I tried switching which port the cable is plugged into but got the same problem. Any ideas? I guess I could buy another wireless adaptor if I can't solve this since our wireless connections never drop, but I'd rather not have to shell out money when the ethernet connection SHOULD work. Thanks everyone!SolvedCan the AC1750/R6400 be used as an extender?
The main router we have is out in the garage and my dads office is on the other side of the house about 125 feet away. We have an extender already in there, but it keeps dropping the signal. We already had the R6400 around, and now I am looking to put it as a midpoint extender between the main point and the extender in the office. Is it possible to use the R6400 as an extender?3.9KViews0likes1CommentAdvanced Settings not working
Hi, I have a problem to open "Advanced Settings" in my R6400 Router, it's like this from beginning (I remember it worked once for me after some firmware update), when I click on this it showes totally nothing (basic works fine). I've tried to enter settings from many different devices (PC, laptops, phones etc.), factory reset, cookies cleaning and logging via different browsers (Chrome, Firefox, Opera, Edge) also don't working. It's an big issue for me for example I can't turn off the lights from router which is really annoying and what is more annoying I can't swtich any advanced settings so basically I don't know how to solve this and I'm waiting for any magical advice.SolvedNo Wifi Connection
The wifi button will not come on. I have connection via ethernet cord but the wifi will not connect. I have reset router and run all tests on the genie. I have not changed any settings. I was given this router by a friend. He literally just bought it and didnt want to go through the trouble of getting it to work or sending it back. (Lazy, rich guy, so he went and bought a new one and gave me this one). Is there anything I havent tried or need to try to get the wifi to work on this dang thing? Please HELP!!!Solved[email failed] Bad sequence of commands after installing firmware 1.0.1.24
I had been getting emails of logs from the R6400 while it ran firmware 1.0.1.6. Since updating to firmware 1.0.1.24, emails fail with the log entry: '[email failed] Bad sequence of commands.' Is this is known problem with firmware 1.0.1.24?SolvedR6400 Weak Power, low range
Hi all I have bought the R6400 to reach all rooms in my house. Sadly, the router from the internet provider has more range and power even if it is standing a floor below. Furhter, the R6400 is unable to get through more than one room or into another floor. (Trough a wood ceiling!!, Not an army shelter) I have the Wlan power on 100 %. If I am right there are three possibilities: Either the router is defect or Netgear is promising ******* or I made a mistake. I would be thankfull if somebody know an answer. FW: 1.0.0.26_1.0.14 Best RegardsSolved
