Remote Access
8 TopicsRemote access via Netgear Genie
I am attempting to enable the remote access feature for my router via the Netgear Genie iOS app. When I try it, it says that “This router does not support remote access.” However, the Netgear website indicates that remote access via Netgear Genie is available for this router (WNDR4000). What do I need to do to enable the remote access on the Netgear Genie iOS app? Thank you.SolvedCan you Remote Desktop to Windows Server via Orbi RBR50 router?
Dear Community, I would be extremely grateful if a member could please answer this question and if it is possible please advise how to achieve. I have been struggling for two weeks and exhausted every avenue. I have a windows Server 2012 R2 that Id like to place on my home network and access away from home. I use an Orbi RBR50 with one additional satellite. The server is configured correctly for Remote Desktop as it was working when in a business location previously. I can also connect to the server using RDC locally through my LAN. I have enabled remote access in the advanced Orbi settings and configured port forwarding on port 3389 to the server on a static LAN address. I can see ports 80 and 3389 are open through a web checker and can ping the the WAN IP address revieving 4 packers back. However, when trying to RDC away from home RDC is unable to connect to the server login screen? Any ideas please? Shacksie70R8000 no longer connects remotely with Genie app after latest firmware
The Genie app was finally working the way it was supposed with pausing connections, etc but then I went an upgraded to the latest firmware and its hosed up Genie. It shows two routers now, one with a serial and one without. I can't connect to the one with the serial number anymore. The second one lists as R8000 (N/A) and doesn't allow remote access. Anybody have any idea what happened here? It's like the firmware upgrade created a duplicate router entry in Netgears DB and they don't match anymore. Please help!!14KViews0likes42CommentsRemote Access For Dummies
I apologize if this is asked and answered somewhere in this maze of a website, but I have been going in circles for 30 minutes trying to find the simplest of answers: how? The other day, I was at work and the router needed rebooting. No one was home except for my wife and she didn't know how to do it. Finally, in desperation, I told her just to unplug the thing, wait 30 seconds or so, and plug it back in. When I dowloaded Genie, I saw something about "Access your router from anywhere". So I thought it might be a good idea to learn how to do it, in case we had another problem and I was at work, I would know exactly what to do. So tonight I came here to do a little research. Little is the key word, because I can find precious little information on how to do it. I can't even find the freaking login page, I don't know if there is a login page, or if I'm supposed to access my router from the Genie program. So, I'm asking that someone give me a "Remote Access For Dummies" lesson. I have a laptop computer, Windows 10, with Netgear Genie installed on it. Obviously, I have created a Netgear account, or I wouldn't be typing this right now. Also, if I can do this on my phone, I do have the Netgear Genie installed on it as well. It is an Android phone, an LG G4 to be exact. Anyone who would like to tackle this, or at least point me in the right direction would be my hero. Thank you.Solved6.9KViews0likes2CommentsR7000 remote device not showing up in iOS Mobile Netgear Genie App
I have been using the Netgear Genie App to control my router from my iPhone 6 for a couple months. It worked great! I have an account, I was able to use Network Map to block/open wifi on my devices at home. Then, a few weeks ago, it just wouldn't show up anymore in my Remote Devices when I log into my Remote Access. I have upgraded my router, upgraded my NetGear Genie on my desktop. My iOS app seems to have been updated automatically if it was needed. I really do not know what else to do.Solved6.4KViews0likes4Comments
