fury88
Mar 14, 2017Star
R8000 no longer connects remotely with Genie app after latest firmware
The Genie app was finally working the way it was supposed with pausing connections, etc but then I went an upgraded to the latest firmware and its hosed up Genie. It shows two routers now, one with a serial and one without. I can't connect to the one with the serial number anymore. The second one lists as R8000 (N/A) and doesn't allow remote access. Anybody have any idea what happened here? It's like the firmware upgrade created a duplicate router entry in Netgears DB and they don't match anymore. Please help!!
Just did a factory reset. Same issue. Will try to unregistered next. BTW this is what I see when I try to use the genie app ever since I upgraded to latest firmware. Two routers now show up. One has my serial number the other is N/A.
Part 2: Re-register fail
DexterJB It's kind of disappointing that I'm actually troubleshooting for your guys instead of the other way around. I should get paid for this.
1. Downgraded firmware to x.x.32. Everything works again.
2. Was able to unregister the router
3. Upgraded to current firmware x.x.36
4. Re-registered (only one shows up now)
5. Same problem. It won't log into the router from the Mac Version of the Genie NOR the iOS version of the app. It just spins and spins and then says Login Failed. Router timed out.
There CLEARLY is something wrong with the apps connection with the new firmware. Hopefully you guys actually acknowledge it and fix it soon. I can't be the only one having this problem. Until then, back down to x.x.32
- David_KayAspirant
Wish I could help, but I'm having the same problem. I just "upgraded" from a 6th gen Airport Extreme because the idea of managing my network remotely from my phone was appealing. I tried a handful of other options, but finally gave the Netgear R8000 a shot because of mostly positive reviews.
Now I'm having the same problem where I can't login to the router from the Mac Genie app or from the iOS Genie app. I've tried restoring to defaults at least 5 times for this issue alone, un-registered and re-registered a handful of times, and completely removed the apps and re-installed them a few times as well - nothing has fixed this so far.
The idea of having to downgrade the firmware is not very appealing, as I understand there was a big security flaw with some previous version that was recently (?) fixed.
One last thing that bothers me is the lack of iOS/Android support for the VPN server - this was another reason why I chose this router. I run a VPN server on my local server, but the idea of running the VPN server from the router itself sounded nice. Then I found out that it doesn't support iOS or Android yet. Why? This seems like a pretty big miss on the Netgear end. Sure, there are third party firmware options, but I shouldn't have to seek those out and mess with the firmware to support something that should be supported by this router natively.
In the end, I'll give it a week to test run it, but so far it's just been one thing after another. Oh man, don't even get me started on how long it takes to boot up.
- dr_nefariousInitiate
Any fix to this yet? Or time for a new brand of router?
- DexterJBNETGEAR Moderator
Hi all,
This has been reported to engineering and is being worked on. We will provide an update once available.
Dexter
Community Team
- SveinsenInitiate
Same thing here, after update I get two routers, and iOS won't connect. A solution shud be very close or this router is going back to the dealer...I have 20 something days left for money back guarantee...
- NspcincInitiateThis is here is just plain sad netgear guys come on help us out.
- Sanctus11AspirantI have similar issues- I Can reboot once from my app once - then I get errors and need to manually reset? Used to work flawlessly from app a few days ago ...
I've still remained on the previous version. I think I had a response from one of the guys and I ignored it. Tired of being guinea pig for companies when I find something wrong. There was an app update a while back. If someone can confirm it works then I'll upgrade. Otherwise, I don't know. I've been looking into the Orbi mesh product but I'm second guessing whether than's worth it.
- Yabx2TutorI am still ybder warranty and have done lots of trouble shooting after the latest firmware upgrade. Still no luck cannot access router using my galaxy s8. The feature that made me buy this a router is only available on the app, setting parental control per device. I want to return the router and get linksys/cisco instead. If we think about it Netgear broke broke our routers.
- AbeebersAspirantI have been having this same problem! I just bought this router 3 months ago so this is very frustrating not being able to use these features
- Yabx2TutorI am calling this weekend and will ask for my money back. If Netgear cares they should send an email or statement at least to all the owners.
- Yabx2TutorSame here I have three kids and made me buy this router. It work for couple months and this latest firmware made it useless.
This is a basic thing that has to work, and it should be very easy for Netgear to solve. I got R8000 today. Shocking to find so little will to resolve or find a workaround - for months that is... Can we trust Netgear to even try solving this?
