We have got your request. just call Netgear Support Number 1-888-344-0222. We will help you to fix your issues
5 TopicsSerial number is changed to NONE000200000 and mac address is changed to 00: 50: 43: 02: 00: 00 RN102
Hi, after a raidar malfunction reported "management service is offline". Then I removed the discs and tried to reset the S.O. Now I connect as an administrator but I notice a very strange thing: the serial number has changed to NONE000200000 and moreover the mac address is changed to 00: 50: 43: 02: 00: 00 completely different from the factory.I think that I have not reinserted hard disk because I'm running a copy of the data after installing with linux the partition with mdadm. What can I do. Thanks in advanceSolved1.9KViews0likes6CommentsReadyNAS Surveillance 1.1.2 Live View and Playback windows black; broken by FW update?
ReadyNAS RN104. I installed the ReadyNAS survelliance app and was fairly pleased with it in demo (1 camera) mode. A bit of extra work to get the Java to work with various browsers, but otherwise fine. Playback worked and I was able to find specific events and play them back. I then noticed that interesting had happened in front of the camera, and went back to the Surveillance app to see what had occurred, but the live view and recording tabs were black. I tried it again with different browsers and O/S's (windows, OSX, Linux) with identical results. Thinking this might have been due to a recent FW update to 6.9.2, I updated to 6.9.3. Same black output screens. I did note that the pages were generating an error on the console: Failed to load resource: the server responded with a status of 404 (Not Found) on http://reddynas:5100/csrf.js?i=0511 The admin page itself loads fine and does not get this 404 error. Any thoughts or comments from others using this app sucessfully would be appreciated. --Ken1.8KViews0likes4CommentsSystem Volume Root usage 92%
Tried to access my unit after extended period of inactivity initially everything looked but wouldn't download system update. Tried rebooting and now can't access volume and it shows no shares though it shows volume is healthy and all apps are gone. Only http and https services are working, others refuse to start giving errors. Believe i need to clean the root volume but have no idea how and can't install apps. Tried to reinstall OS using boot menu to see if that would help but no go. want to avoid factory reset and loosing my files. Most are no big deal but I really need to get the last few things I put on there right before this happened. Any help would be appreciated logs that I have shown now. Sat May 12 2018 8:00:53 Volume: System volume root's usage is 92%. This condition should not occur under normal conditions. Contact technical support. Fri May 11 2018 23:59:35 Volume: System volume root's usage is 92%. This condition should not occur under normal conditions. Contact technical support. Fri May 11 2018 23:59:28 System: Alert message failed to send. Fri May 11 2018 23:59:29 System: ReadyNASOS background service started. Fri May 11 2018 23:59:28 Volume: Less than 10% of volume media's capacity is free. Performance on volume media is degraded. To improve performance, you must add capacity.1.1KViews0likes4CommentsConnecting two WAC510 to the same network
I have two WAC510 in my house to improve coverage. I am trying to assign independent SSID to each one. Using the portable application from a mobile device I have created multiple SSID but I dont find a way of assigning them to a specific WAC510. Can someone provide ideas?Solved4.3KViews0likes2Comments
