apps
73 TopicsWiFi Extender Won’t Connect to Some Apps/Sites
My Network: AX3600 Insight Managed Router (Firmware version 10.2.0.16), AX1800 Mesh Extender (Firmware version 1.0.3.36) Issue: I recently got a new router and a range extender to help cover my whole house, but I’m running into a weird issue. When any device (phone, desktop PC, laptop, iPad) connects via the extender, it loses the ability to connect to some websites. For instance, I can connect to Facebook fine, but if I try to connect to Twitter, it fails to load. When I try to connect to those sites via the Wi-Fi from the router, everything loads perfectly. Attempted Fixes: Factory reset of both devices, firmware update, cycling both devices and the modem, cursing.NIGHTHAWK EX7000 AC1900 WI-FI RANGE EXTENDER WON'T CONNECT TO NIGHTHAWK APP
The Nighthawk app sees my SSID from the Nighthawk Ex7000 Ac1900 Wi-Fi Range Extender but will not connect. The range extender is working properly, devices are connected and operating but the Nighthawk app will not connect. Suggestions?1.2KViews0likes4CommentsAbout Nighthawk EAX80 Extender Security Type Setting
Firmware Version V1.0.1.70_1.0.2 I find that there is an option "WPA2/WPA3-Personal" for WIFI Security setting in the Nighthawk app but missing it in the Web interface. If I change any wifi settings by the web interface, the security setting in both the web interface and the app will be completely set as other options instead of "WPA2/WPA3-Personal". Didn't NETGEAR notice this problem? I'm surprised no one noticed it after all this time. The "WPA2/WPA3-Personal" is completely missing in the web interface setting.😢 Please fix it. Thank you.🙏611Views0likes0CommentsAdd an already configured EX7000 to the Nighthawk App
Hello, I've manually via the webpage configured my EX7000 and it's working great, however when trying to add it to the Nighthawk app it wants me to connect to SSID "NETGEAR_EXT". That doesn't seem to show up, just the networks that I have configured do. I'm also on one of those networks with the phone I have the app on, but it seems that I have to be connected to the SSID above. So my question is: is there a way to add an already configured extender to the Nighthawk app without resetting the router and starting over? Would appreciate any input, could be a simple mistake on my part. Thanks!691Views0likes0CommentsHow to resolve weak signal issues with NETGEAR N300 Wi-Fi Range Extender EX2700?
I'm currently encountering difficulties with my NETGEAR N300 Wi-Fi Range Extender EX2700 as it is exhibiting a weak signal. This weak signal is hindering the establishment of a stable and reliable Wi-Fi connection throughout my entire home. To address this issue, I would greatly appreciate any suggestions, troubleshooting steps, or tips that could assist me in enhancing the signal strength of my Wi-Fi range extender. My primary objective is to ensure a consistent and robust Wi-Fi signal coverage throughout my home, allowing me to seamlessly connect all my devices and access the internet without interruptions. Given the importance of a reliable internet connection for various tasks such as work, entertainment, and communication, resolving this weak signal problem is of utmost importance.AC1900/EX6400V3 - In the weeds!
AC1900/EX6400v3 Range Extender. My range extender worked flawlessly for seven months and now refuses to show up on my list of available networks. Multiple factory resets and re-installs by the book. I'm close to just throwing this thing out the window. So - there's a Nighthawk app and and actual Nighthawk router product. (I can't be the only one thrown by this). Am I correct in understanding that the Nighthawk app gets used with all the products? thanks in advance for useful insights!850Views0likes3CommentsEAX20 Mesh Extender stuck during setup
Trying to setup an EAX20 extender to go along with our CAX30 modem/router using the latest version of the Nighthawk iOS app. Every time I had tried to do so, the EAX20 gets stuck on trying to connect to the 5G signal (screenshot attached). I had left this overnight in the past and no luck. I have tried closing the app and restarting the process but then the app is unable to join NETGEAR_EXT network to even initiate the process. I have to reset the extender to attempt again but get stuck at connecting to 5G each time. Please help! Thanks!Nighthawk CAX80 Err_cert_authority_invalid
When connected to my network, all devices give me this error: NET::ERR_CERT_AUTHORITY_INVALID I've reset my modem, both through the app and routerlogin.com. I've replaced the coax, sent refresh signals from Xfinity, and checked that the timezone and firmware is correct and up to date. Possibly unrelated, but also every time I go in to admin settings, it makes me put a new admin pw and sec questions. It doesn't save it from last time. Currently I just refreshed again from Xfinity app, and it's still not functioning. Any suggestions?1.1KViews0likes0CommentsCant login to nighthawk app
My extender is working but I cannot login to the app, I've tried resetting the extender, tried clearing cache, can't reset password, can't use routerlogin.net or mywifiext but I was able to login on the computer. How do I get the login to work on the app? Using an s10 phone?730Views0likes0Comments
