business essentials
7 TopicsWAX220 Access Points How to Enable SNMP?
WAX220 Access Points How to Enable SNMP? I have a valid account, I have enabled 2FA, I attempt to login in to the insight portal we page, get access denied instantly. I login to the iPhone app, and it shows me no devices available on my network, I have multiple WAX220 devices that exist and are actively working. So now what?DFS Channels: How to access on the WAX210?
The promotional materials for the WAX210 indicate the hardware supports using DFS channels. The manual even gives a stern warning that I am responsible for proper use of these channels. This access point is being used in an environment with a lot of neighbors not under my control, two nearby apartment buildings and multiplexes across the street. It would be really good to be able to use some of the DFS channels which have a lot less traffic on them. I have been unable to locate where in the UI those channels can be unlocked. How can one access the DFS channels on the Wax210? Suggestions would be appreciated!272Views0likes7CommentsAP WAC124 doesn't work after upgrade!
Hello, I updated my WAC124 AP from WAC124-V1.0.4.4 to WAC124-V1.0.4.9 via webgui, but it stuck without completing the update. So I tried an older firmware version, WAC124-V1.0.4.6, downloaded from the official website. After updating, the AP stopped working. When I turn on the AP, the LED stays solid and no other LEDs light up. The reset button doesn't seem to work; after holding it down for more than 10 seconds, nothing changes (with the AP on). If I press the reset button with the AP off and then restart it, I see that the power and USB LEDs light up alternately and stay that way forever. What can I do to fix this? Thank you!My WAX220 is showing a shadow network "SP RED TEST ONLY"
Hi, I noticed some month ago a weird access point name on my phone, and I came to the conclusion that it came from my Wax220. I tried to reset it, getting it to the latest firmware (1.0.3.5) but it does nothing : as soon as the device is reset, we only see the configuration AP, but when the device is setup, the shadow access point always comes back. Stopping the configuration AP does nothing. What can I do to get rid of this ? Is there a procedure? I tried flashing from the IMG file it didn't help. Thanks for your helpWAX220 WIFI Disconnects on Apple devices
Please help, this has been doing my nut in. WAX220 WIFI AP for some reason keeps disconnecting Apple Iphones for a minute frequently and causes calls on facetime to freeze and become unsuitable to continue. I have 1GB Virgin Cable using the VM Hub 5. Do you have any ideas that could be of help? Thanks Coops11KViews0likes58Comments
