cm2000
4 Topics"US profile assignment change. " and "DBC-REQ Mismatch" in modem event log
Every once in a while I'll get a massive lag spike that I can plainly see happen because I am running PingPlotter while playing a game to monitor my connection. Since I don't know what is causing it I went to look at the modem log to see if there was anything noticeable and I saw these warning show up. I want to know what is causing the problem and how they can be fixed. And if it is not something on my end I need to know exactly how to explain it to my ISP so they know EXACTLY what to look at to fix it on their end because whatever support person I talk to likely won't have any idea what I'm talking about if I show them this information. I have attached a screenshot showing the modem log. My second question would be is there any other way to monitor my connection to see what could cause any other ping spikes? Like if I can see it happen on PingPlotter I'd like to know what made it do it to begin with.Solved136Views0likes3CommentsWhy is Xfinity blocking access to the spectrum analyzers?
Copied from a reddit discussion on the unofficial Comcast page. Could not get a definite answer. Recently discovered that port 8080 buy doing a port scan of the modems log in IP that Comcast is blocking the analyzer by http proxy. Why are they blocking this? It wasn't enough that they told modem manufacturers to not display unerrored codewords. Now we can see the analyzers now. There was a short window where I could access it, where I would disconnect the coax cable from the wall plate. Then allow the modem to lose connection, after that I could see it for a few seconds. Before the modem downloaded the configuration file. There was a log in page to get to it as well. Does Netgear use any services on port 8080 with their modems?271Views0likes3CommentsCable Modem for Xfinity (August 2025)
Xfinity identifies the following older Netgear modems as compatible for my location: Netgear CM1100 Netgear CM2000. (I do not require Voice or WiFi in the modem.) Seeking recommendations for whether I should purchase the newest available Netgear modem or should I seek one of these older models? If a newer model, are there any to be avoided?Solved897Views0likes6CommentsIs the Netgear CM2000 end of life now?
Just a question if the Netgear CM2000 is EOL now? I am only using it right now as I dont know when Xfinity will roll out mid split. Once they get it going in my neighborhood I will get the CM3000. Another question is should I not expect any more firmware updates for it?Solved790Views0likes2Comments
