nighthawk mesh
348 TopicsWiFi Extender Won’t Connect to Some Apps/Sites
My Network: AX3600 Insight Managed Router (Firmware version 10.2.0.16), AX1800 Mesh Extender (Firmware version 1.0.3.36) Issue: I recently got a new router and a range extender to help cover my whole house, but I’m running into a weird issue. When any device (phone, desktop PC, laptop, iPad) connects via the extender, it loses the ability to connect to some websites. For instance, I can connect to Facebook fine, but if I try to connect to Twitter, it fails to load. When I try to connect to those sites via the Wi-Fi from the router, everything loads perfectly. Attempted Fixes: Factory reset of both devices, firmware update, cycling both devices and the modem, cursing.5.4KViews0likes7CommentsMy extender won't connect to my new router
I recently changed internet providers and now my extender won't connect. I factory reset it and used the Nighthawk app to set it up. On my phone it says it's connected, but the extender itself doesn't show it's connecting. I also have an ethernet cable connected from the extender to my desktop. My desktop still isn't connecting to the internet, so I know the extender isn't working. I called support and after TWO hours, they were unsuccessful in helping me. I'm calling back again and I've now been on hold for an HOUR! This is ridiculous. Unhappy is an understatement. Please help.2.1KViews0likes3CommentsMR70 Loses Advanced Routing Settings
NightHawk #MR70 mesh system V1.0.3.34_2.0.58) is set up with advanced routing to some custom TCP/UDP ports. After a while (ranging from days to weeks), the advanced routing stops. When I go in to look at the settings, the list is blank. If I try to add the rules again, the system presents the message that the rule conflicts with existing service. However, when I try to search the rule it does not exist and the list remains blank. The only (temporary) solution I've found is to completely factory reset the system and re-create all the rules. Unfortunately after a few days the problem returns. I've tried backing up the settings and restoring from the backup, however the same problem persists upon restoration, even if the settings are backed up after a freshly reset system which should be error free.EAX20 - AX1800 configured as access point only allows single wifi user
I have setup a EAX20 - AX1800 extender as an access point in my garden cabin with an ethernet connection back to the AC3200 router. Connected via ethernet to the access point are two sky stream pucks, which work with no problems, and a WDCloud network storage device serving up shared NFS mounts with no problem. I configured the 2.4ghz and 5ghz wifi bands to match the ssid and passwords of the main routers wifi, and my MacBook and iPhone can both connect to both wifi bands. However, when there are multiple devices connected only one has access to the internet. Either device works with internet access when connected singly but when both are connected only the first device connected has access. I've tried resetting extender and I've tried rebooting the main router, but the problem remains. I would appreciate any pointers on how to resolve. Thanks1.3KViews1like5CommentsMR60
I'm looking at buying the MK83 mesh wifi for my home, I currently have the MR60. I was wondering if I keep just the satellite from the MR60 will it work with the MK83? If it will work, does it automatically sync or do I have to manually add it and what does that include? Yes I have a need for 3 satellites and 1 base. I'm trying to get signal to parts of my house that are faraday caged so to speak and moving the metal isn't an option.Nighthawk EAX80 not connecting with Nighthawk RS700s
I’m trying to add an EAX80 to my router to allow the whole house to be covered. However, I can’t add the extender via the app and only via the WPS. When I use the app I can’t see the extender and also can’t see who is logged into it. When I tried to set up via the app i was joining the NETGEAR_EXT network, but then it was continually defaulting to the router network and then saying that the extender could not be located. The main purpose of getting a Nightgear was to restrict our internet obsessed children. However, as they are on the extender which I can’t see I am unable to set time limits etc. Please help!!1.5KViews0likes7CommentsEAX20 extender issues
I have a Nighthawk RAX80 router and a AX1800 Mesh Extender EAX20 extender, it is connected however i am noticing that it will randomly lose connection to either the 2.4 ghz or the 5 ghz signal from time to time. Rebooting doesn’t bring it back, i have to go through the whole setup process again on the extender to get it back to normal. There is a nearby active ethernet port that is connected to the router, would i be able to connect the extender to ethernet rather than wireless meshing and still keep it in extender mode with One WiFi activated? Nighthawk RAX80 - Firmware Version V1.0.10.140_1.0.79 AX1800 Mesh Extender EAX20 Firmware Version: V1.0.1.64_1.0.1041.5KViews0likes5CommentsNIGHTHAWK EX7000 AC1900 WI-FI RANGE EXTENDER WON'T CONNECT TO NIGHTHAWK APP
The Nighthawk app sees my SSID from the Nighthawk Ex7000 Ac1900 Wi-Fi Range Extender but will not connect. The range extender is working properly, devices are connected and operating but the Nighthawk app will not connect. Suggestions?982Views0likes4CommentsCan Any MS70 satellite be added to a MR70 router? Or is each MS70 paired to its router?
When staying with family connectivity to the Nighthawk MS70 is fair due to distance. I was wondering if I could take one of my MS70 satellites and use it with their system or is each satellite paired with the MR70 router? Both systems were purchased at Costco and came with the router and 2 satellites. Or should I just look at an extender? Thank you.Solved1.4KViews0likes1Commentcreating offline mesh network, without internet , what model i should use? most needs internet
hello, i hope you have a great day, looking to create an offline local mesh network to make our devices contact one another, most routers i found needs to be connected to a central modem (internet company modem) and it just creates bigger network. i need to create one big mesh network using more routers with one name, what models should i look into. thanks in advance2.7KViews0likes3Comments
