orbi wifi 5
13 TopicsUsing signal strength detection to place Orbi Satellites FAQ
This document describes how to use Wi-Fi signal strength detection to optimally place Orbi satellites — both their location and the total number deployed. A common mistake is placing more satellites than necessary under the assumption that “the more, the better.” In mesh networking, however, the opposite is often true. Too many Orbi units can create excessive signal overlap, leading to disconnect issues, poor roaming behavior as devices move throughout the house, and general instability. In many mesh environments, deploying fewer units produces better overall performance. To do this properly, you need a software application that displays real-time Wi-Fi signal strength. There are several free tools available. I use a Mac laptop and walk through the house running one or both of two tools: WiFi Explorer Lite and iAnalyzeWiFi. Both are free and available in the Mac App Store. Comparable tools exist for Windows, likely even more of them. These tools provide a real-time view of all detectable Wi-Fi signals in and around your home. As a side benefit, reviewing signal strength across bands can also reveal excessive channel contention on 2.4 GHz, 5 GHz, or 6 GHz bands from neighboring networks. There are two placement strategies depending on whether a satellite (RBS) will use wired (Ethernet) or wireless backhaul. With wired backhaul, you should place the satellite in the weakest signal area that you can physically reach with Ethernet. Since the backhaul is wired, you do not need strong Wi-Fi at that location. Instead, you are extending strong coverage into a previously weak Wi-Fi signal area of the home. With wireless backhaul, the strategy is different. You must place the satellite in a strong signal area so that the backhaul connection to the router is fast and reliable. However, you should place it near the outer edge of that strong coverage zone. The goal is to extend strong Wi-Fi into areas that previously had limited coverage while maintaining a robust backhaul link. In summary, it is inefficient to place a wired-backhaul satellite in a strong signal area, and it is equally inefficient to place a wireless-backhaul satellite in a weak signal area. The key is to do the opposite in each case. When physically placing router and satellite units, also consider environmental factors. Avoid placing units near large metal appliances, electrical panels, HVAC ductwork, or thick masonry or concrete walls, as these significantly attenuate Wi-Fi signals. Do not place units inside cabinets or behind large objects. Elevating units on open shelves or furniture typically produces better coverage than placing them low to the ground or hidden in enclosures. Start by powering down all satellites so that only the router (RBR) is active. Walk around and record signal strength throughout the home. Then place the first satellite (RBS) based on the measured signal coming from the router — strong signal if using wireless backhaul, weak signal if wired backhaul is available. In multi-story homes, also consider vertical coverage. Wi-Fi signals do not only travel horizontally; they pass through floors and ceilings as well. Materials such as reinforced concrete, tile, or radiant floor heating can significantly reduce signal strength between levels. Stairwells often allow better vertical signal propagation. When mapping signal strength, test both directly above and below router and satellite locations to ensure balanced coverage across floors. After the router and first satellite are powered up, repeat the signal mapping process. Identify remaining weak areas and determine whether those areas truly require stronger coverage. Not every corner of a home needs maximum Wi-Fi strength. This evaluation will determine whether an additional satellite is necessary. If adding another RBS, try placing it as far as practical from the router or existing satellites. Netgear recommends a minimum separation of 30 feet, but generally, the farther apart they are (while still maintaining adequate backhaul signal), the better. Using the Mac applications mentioned above, you can view signal strength in RSSI (Received Signal Strength Indicator), which simplifies evaluation. As a general guideline, look for an RSSI of at least –67 dBm or stronger for reliable wireless backhaul. Remember that “stronger” means closer to zero on the number line (for example, –50 dBm is stronger than –67 dBm). In many cases, you can stretch to –70 dBm if necessary, but performance may begin to degrade below that threshold. Once two satellites are deployed, continue walking through the home measuring signal strength and performing speed tests. Only after this evaluation should you decide whether an additional satellite is objectively necessary. In addition to laptop testing, validate performance with real-world client devices such as smartphones, tablets, streaming devices, and laptops — especially in the areas where you spend the most time. Different devices have different radio capabilities and antenna designs, so real-world testing ensures that the theoretical signal map translates into practical performance. An additional benefit of these signal analysis tools is the ability to see each Orbi node (RBR and RBS) individually. This allows you to detect excessive overlap. If you observe nearly identical signal strength from two or more Orbi nodes in the same area, it may indicate too much overlap. Significant signal conflict can make it difficult for client devices to roam smoothly between nodes as they move throughout the house. This is something to test as well; ensure that there are no disconnects or poor network performance on a mobile device when walking around the home in your primary paths. Many users are surprised to discover that they need fewer satellites than they originally expected. To do this right, you need a software app that shows real time WiFi signal strength. There are several free ones. I use a Mac laptop and walk around the house running either/both of 2 tools - WiFi Explorer Lite and iAnalyzeWiFi. Both are free and in the Mac App store. There are comparable tools in the Windows world, if not more of them. Both of these Mac tools will give a real time view of ALL signals in your house where you are standing. Wifi Heat Map - Survey for Android on a tablet. https://play.google.com/store/apps/details?id=info.wifianalyzer.heatmap&hl=en_US&gl=US Article originated and authored by donawalt249Views0likes0CommentsCircle Pass Code Help and Information
For users needing help and information regarding Circle Pass code: https://support.meetcircle.com/hc/en-us Having problems getting Pass Codes? https://support.meetcircle.com/hc/en-us/articles/115001381012-Circle-1st-Generation-Passcode-Issues How Do I Manage My Circle with NETGEAR Premium Subscription? Apple Click here for more information on how to cancel a subscription on your Apple device. You can request a refund for an Apple in-app subscription or purchase by following the guidance here. Google Play Click here for more information on how to cancel a subscription on your Android device. To request a refund for In-App subscription purchases, click learn more about refunds from Google Play here. For additional help and information regarding Circle Pass Codes, please contact NetGear support: https://my.netgear.com/support/contact.aspx To get a hold of support for subscriptions services like Armor/Circle, click on "MyNetgear" at the top. Register an account (or log in) and then click on the device. From there, you can start the support process. Click on: My Support---->Contact Support---->Get help with my subscription service NOTE: Circle feature has been discontinued with NG: https://kb.netgear.com/000063022/Support-for-Live-Parental-Controls-ends-April-1-2021 Smart Parental Controls is now it's replacement: https://www.netgear.com/home/services/smart-parental-controls https://kb.netgear.com/000063635/How-do-I-get-help-with-my-NETGEAR-subscription-service114Views0likes0CommentsNETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ
Summary: Since Android/Apples and Windows introduction of MAC address randomizers in there OSs, this seems to have been causing problems for users of Netgear's mobile applications, i.e. Nighthawk and Orbi applications on iPhones and iPads being able to connect correctly to Netgear router products. What is: Apple WiFi Private IP Address: "Apple platforms use a randomized media access control address (MAC address) when performing Wi-Fi scans when not associated with a Wi-Fi network. These scans can be performed to find and connect to a known Wi-Fi network or to assist Location Services for apps that use geofences, such as location-based reminders or fixing a location in Apple Maps." https://support.apple.com/guide/security/wi-fi-privacy-secb9cb3140c/web Try only disabling this feature first as a first step in troubleshooting. If the above feature change doesn't work or help change anything, try the following: Apple Limit IP Address Tracking: "Limit IP address tracking is a privacy-enhancing feature currently only seen on iPhones or iPadOS devices with cellular connectivity. This feature can be activated on your device if you are running iOS 15.2 RC 2 or higher. Once enabled, your IP address will be hidden from identifiable trackers in Apple’s database. This feature will only work in Safari & Mail, for now, using another browser or Mail app will leave you exposed to trackers. https://nerdschalk.com/hide-ip-address-on-iphone-how-to-use-limit-ip-address-tracking-feature-for-this/ https://discussions.apple.com/thread/253657312?answerId=256849570022#256849570022 Apple iCloud Private Relay: "When Private Relay is enabled, your requests are sent through two separate, secure internet relays. Your IP address is visible to your network provider and to the first relay, which is operated by Apple. Your DNS records are encrypted, so neither party can see the address of the website you’re trying to visit. The second relay, which is operated by a third-party content provider, generates a temporary IP address, decrypts the name of the website you requested and connects you to the site." https://support.apple.com/en-gb/HT212614 These two above features may not need to be changed. 2024 Apple has implemented additional options to the Private WiFi Address feature: 3 options are now seen here: Disable - Disables the MAC address randomization on the phone. Uses actual MAC address set on the phone. Fixed - Sets a fixed MAC address that differs from actual MAC address of the phone. Rotating - Randomized the MAC address. Good for traveling or connecting to open WiFi networks when away from home. Diagnosis: When users are at home that these features may not be needed as there would be no reason to have additional security features on the iOS devices enabled while being at home and that these features are more suited for out of home or remote use while away from home and the local home network. Solution: For troubleshooting these problems with Netgear mobile applications, Apples WiFi Private IP address and Limit IP tracking on Apple iPhones and iPads can be disabled while at home to see if this helps resolve Netgear's mobile app in connecting to the Netgear router. Try turning OFF WiFi Private IP address and Limit IP tracking features are found on the same screen page: https://support.apple.com/en-us/HT211227 iCloud Relay can be turned off as a troubleshooting step as well though may not be needed in most cases: https://support.apple.com/en-us/HT212614 ANDROID: Also seen on Android OSs as well: https://www.howtogeek.com/722653/how-to-disable-random-wi-fi-mac-address-on-android/ NOTE: For Android devices, there is only Disable and Phone/Tablet MAC options. MS WINDOWS: Seen on Windows PC or Laptops with WiFi adapters: NOTE: These are troubleshooting steps only and recommended trying if all other troubleshooting steps fail. Remember to enable these Android/Apple and Windows features when using Android/Apple/WIndows devices normally or remotely outside of the home network. If users still see problems with the mobile app after trying the solution, please submit a bug using the submit bug feature in the app: Orbi App: https://community.netgear.com/t5/Orbi-App/How-to-report-a-bug-on-the-Orbi-App/td-p/2140980/jump-to/first-unread-message Nighthawk App: https://community.netgear.com/t5/Nighthawk-App/How-to-report-a-bug-on-the-Nighthawk-App/td-p/2134684/jump-to/first-unread-message Or contact Netgear support: https://my.netgear.com/support/contact.aspx917Views2likes0CommentsOrbi MESH Troubleshooting, Suggestions and Tips
This is initial information regarding Orbi help, troubleshooting and tips to help users who encounter Orbi problems. Users should review this and test the suggestions and tips out and post your results and questions if more help is needed in the forums. Most problems seen are mis-configurations, environment and or ISP service related. Please review the following attached PDF information file and if your needing additional help. Please copy and paste the template of questions and suggestions, which pertain to your particular problem, to include in your posts so we may get a better idea of your systems setup and provide better feedback to help you resolve and fix the problems users are experiencing. It's for the users and posters benefit to be detailed as much as possible when posting and to answer and give feedback to the questions and suggestions presented by other users. Some of these questions and suggestions will need to be answered so we can help you and give you better feedback and work to help resolve the problem.1.3KViews0likes0CommentsArmor Help and Information FAQ
For users needing help and information regarding Armor: NETGEAR Armor Protect Your Family and Your Home Network from Cybersecurity Threats https://www.netgear.com/home/services/armor/ https://armor.netgear.com/ What are the features of NETGEAR Armor? https://kb.netgear.com/000059435/What-features-does-NETGEAR-Armor-offer How do I start a subscription for NETGEAR Armor? https://kb.netgear.com/000059444/What-is-the-available-subscription-plan-with-NETGEAR-Armor Prerequisites and What Products support Armor? https://kb.netgear.com/000059437/What-are-the-prerequisites-to-use-NETGEAR-Armor https://kb.netgear.com/000061281/Which-products-support-NETGEAR-Armor How to Use and Activate Armor: https://kb.netgear.com/000059442/How-do-I-activate-NETGEAR-Armor-using-the-Nighthawk-app https://kb.netgear.com/000060582/How-do-I-activate-NETGEAR-Armor-on-my-Orbi-router https://kb.netgear.com/000060247/How-do-I-activate-my-NETGEAR-Armor-subscription-using-an-activation-code Armor Subscription Update Information: My payment method needs to change. How does one update their payment method for auto-renewal of my armor subscription? Enter or update details by browsing to this link: https://accounts.netgear.com/account Then you can edit your card payment details. Help with your subscription service? https://kb.netgear.com/000063635/How-do-I-get-help-with-my-NETGEAR-subscription-service How do I unblock URLs in NETGEAR Armor? https://kb.netgear.com/000061715/How-do-I-unblock-URLs-in-NETGEAR-Armor Armor Support Information and Help: https://kb.netgear.com/000061809/I-get-an-error-when-I-try-to-activate-NETGEAR-Armor-what-do-I-do https://kb.netgear.com/000062125/Why-didn-t-I-receive-an-activation-code-after-purchasing-NETGEAR-Armor-from-the-NETGEAR-Store https://kb.netgear.com/000059445/How-do-I-subscribe-to-NETGEAR-Armor-after-my-free-trial-expires https://kb.netgear.com/000059447/Can-I-add-more-than-one-router-to-my-NETGEAR-Armor-subscription https://kb.netgear.com/000059446/How-do-I-cancel-my-NETGEAR-Armor-subscription For additional help and information regarding Armor, please contact NetGear support: https://my.netgear.com/support/contact.aspx To get a hold of support for subscriptions services like Armor/Circle, click on "MyNetgear" at the top. Register an account (or log in) and then register the device. From there, you can start the support process. Click on: My Support---->Contact Support---->Get help with my subscription service163Views0likes0CommentsSupport and End of Service FAQ
We understand that a primary reason you might be visiting the NETGEAR Community is that you are looking for answers to your support questions for NETGEAR Wi-Fi Routers, Firmware, and setup procedures for your NETGEAR Products. We are here to help and want to get you an answer as quickly as possible! Information about what NETGEAR products have reached End of Service life: https://www.netgear.com/about/eos/ 3rd Party FW Support after End of Life If the unit is still working and you want to continue using it, consider reviewing the following 3rd-party FW sites for FW support on their supported models they support: https://openwrt.org/supported_devices https://dd-wrt.com/support/router-database/ http://www.voxel-firmware.com/ NOTE: These sites handle 3rd-party support, help, and information, not NETGEAR. Otherwise, consider getting a newer generation router. Need more help? Visit the NETGEAR Support page and search for your model number or details on your question. Visit here to search the NETGEAR Community pages.369Views0likes0CommentsRegistration and Un Registering products Help
We recently updated our support site to now allow customers to unregister their products via mynetgear.com. Please follow the steps listed below to remove products from your account. Log into my.netgear.com Scroll down and click View Product button for the product you wish to remove from your account Scroll down and click "Unregister Product" in grey (below the "Community Links" button) You will be asked to confirm you want to unregister your product (*Unregistering your product will remove the product from your account. It may be re-registered to the same account. If it is re-registered to another account, any warranty will not be transferable, per the NETGEAR warranty.) Click "Yes, unregister my product" If you are still having issues registering or unregistering your devices please check out the KB below as it has an Email address to contact. https://kb.netgear.com/1160/NETGEAR-Product-Registration-FAQ313Views0likes0CommentsProcedure to Manually Firmware Update Orbi and Nighthawk Mesh systems.
A guide for user who wish to manually update their systems themselves by using a wired PC and web browser after downloading any new or available firmware update files that maybe available for their models’ systems from NEGEAR 1. How to download firmware files from NETGEARs download site per model system. 2. Unpack downloaded .zip firmware files. 3. Recommended practices to use a wired PC and web browser to manually send firmware update files to the satellite units first, then the main router unit lastly, using the satellite and main router web pages in a web browser. 4. Recommended after update processes to the system to help ensure the update is working well. Power OFF the router and satellites then back ON. 5. MS-Edge(Windows), FireFox(Mac and Windows), Safari(Mac) are recommended browsers Download and acquire the necessary firmware files from NEGEARS download site per model system Navigate to https://www.netgear.com/support/ in a web browser. Locate the model number if need from your main router unit: Be sure to back up the systems configuration to file, before starting a firmware update for safe keeping: Nighthawk Mesh: https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router Orbi Mesh: https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-System Orbi systems will start with CBR, RBK, RBKE or RBE. Nighthawk Mesh systems will start with MK. Input the model number of your Orbi or Nighthawk MESH system: After the model product page displays, select the Downloads button: Firmware and Software Downloads will be displayed in the web browser. Orbi Mesh: Nighthawk Mesh: For all Orbi and Nighthawk Mesh systems, there are two separate firmware files needed to be downloaded. Select anywhere on the Current Versions web page to reveal a download or Release Notes link. Select the Router and Satellite options seen: Orbi and Nighthawk Mesh: A Download button will be displayed along with Release Notes. Two options here to download the necessary firmware files. 1. Select the blue Download button for the router unit then select on the satellite drop down to show the same blue Download button for the satellite: After selecting the download button, the file will be downloaded using the web browser to its designated location or have the browser download the file to your desktop, a recommended location. 2. Select the Release Notes link under the blue download button: This will open the product system download page and show release note information about what is included in the available firmware update along with download link to both router and satellite units: Select both router and satellite .zip files seen here, and the file will be downloaded using the web browser to its designated location or have the browser download the file to your desktop, a recommended location. Example is for Orbi 960 series. Same will be seen for Nighthawk Mesh systems as well. Unpack the downloaded firmware .zip files. Find and navigate to where the download .zip files are located and right select on each of the .zip files. Right select on each file from the tool menu, select Extract All… Other .zip file extractors like .7zip or other .zip file extraction programs may be used here. Extract both the router and satellite .zip files. Select a Destination and Extract the files from the .zip file: Browse to where the extracted files are to be extracted too. Recommended desktop or the default location seen in this window. Users Choice. Select the Extract button and the files will be extracted to this location. Do this for both the router and satellite firmware .zip files. Observe the extracted files. There will be a .chk and a Release_Notes file within the extracted file folder as seen here: DO NOT ATTEMPT to open the .chk file beyond this point. This is the actual firmware file that gets sent to the router or satellite units. You can open the Release_Notes file and view information within that file. Observe and take note of the difference in file names for the router and satellites. Router should have a RBR or MR in the file name. Satellite should appear as RBS or MS in the file name. Prepare the system for manual firmware updating Recommend bringing any remote satellites to near or same room as the router unit for quick and easy observation of the satellites that will be updated along with the main router unit. If any satellites are ethernet connected to the router unit, these can be left in their remote locations. Use a browser and browser tabs. Open a browser and log into the router unit using log in credentials. Once logged in, select on the Attached Devices menu option: Find the IP addresses for each satellite that’s connected to the router unit: Use the IP address seen here for each satellite and open a new tab with in your current opened browser for each of the IP addresses seen for each connected satellite. Log into each satellite’s web page using the same log in credentials for the router unit: The browser should have one tab for the main router web page, then other tabs for each of the connected RBS. Update all connected satellites After logging to the satellite’s web page, select the Firmware Upgrade menu option: This will display a Firmware Upgrade and Upload Upgrade File window in the browser: Select the BROWSE button and navigate to where the downloaded and extracted files are located. Find the satellite .chk firmware file first. After selecting the satellite .chk firmware file, the Upload Upgrade File window will be populated: You can select the blue UPLOAD button here and do this one at a time for each satellite. NOTE: Alternative would be that you can log in to each satellite’s web page on each browser tab and setup the firmware file to be loaded for each satellite on their tabbed web pages. Once you have each satellite setup as above, then select the blue UPLOAD button on the first satellite to be updated and soon after the web page shows the progress circle, select the blue UPLOAD button on the next satellite that needs the file sent, until each satellite has been uploaded top. After selecting the UPLOAD button, a note window should be seen giving information on how long the process takes: Next screen I the browser will be a progress circle: Observe the front LED on the satellite unit(s). It should start to blink WHITE then as the progress circle gets to 100%, the front LED should stop blinking and turn BLUE for 3 minutes indicating a good sync and connection, then turn OFF, indicating normal operation. Do not power off the satellites during this operation. Could cause damage and break the operation of the satellite(s). Once the progress circle gets to 88-100%, the satellites web page will update and display the following: Or Nighthawk Mesh network here as well. Leave the satellite web pages alone here. Note: After the last satellite has been sent the firmware file, you can immediately go to the routers web page and send it’s FW file soon after the last satellite has been sent it’s FW file if it was set up along with the satellite web pages for the firmware update in quick order. Update the routers firmware lastly After each satellite has been sent the satellite firmware, send the routers firmware file to the router unit. Select the Firmware Update from the Advanced tab/Administration menu: Select the Manual Update tab: Select the BROWSE button and navigate to where the downloaded and extracted files are located. Find the router firmware file. Don’t select the satellite firmware file: Select the blue UPLOAD button: You will see a IP address of the router says message: Select OK here. Warning and Note on firmware version and time to process the firmware will be seen: Then a Rebooting the router now message progress bar will display: Observe the front LED on the router unit. It should start to blink WHITE then as the progress bar get to the end, the front LED should stop blinking and turn OFF, indicating normal operation. After all satellites and the router have been sent the firmware files and have process the firmware file and are back to ready. Recommend a power OFF of the router and all satellites for 1 minute then back ON with the router unit first, then satellites, one at a time. If satellites were taken to same room for this operation, can now be powered OFF and returned to their remote locations and powered back ON. Give about 5-10 minutes for the router and all satellites to power ON and come to ready. For Orbi systems, confirm that the front of the router LED turns OFF indicating normal operation and confirm that the satellites LED turns BLUE for about 3 minutes, then turns OFF, indicating normal operation. Orbi Mesh: https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean For Nighthawk Mesh systems, LED on the router and satellites should blink WHITE then turn to BLUE and remain ON, indicating normal operation. AMBER LED maybe seen for a short time on the router and satellites, then turn BLUE. Confirm on the router and satellites web pages that the firmware version has been updated to the version that was downloaded and installed. Confirm operation of the system with your devices. NOTE: If any problems are seen after the firmware update, even after the system was powered OFF then back ON and basic troubleshooting doesn’t resolve the problem, a factory reset will need to be performed to see if this helps resolve the problem observed. https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings https://community.netgear.com/kb/en-orbi-knowledge-sharing/orbi-systems-manual-factory-reset-process/2456340 Or use the ERASE button on the routers web page to factory reset the router: https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System Be sure to save off a new backup configuration to file for safe keeping. Saves time if a reset is needed. https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-System Enjoy. KB Articles and References: • https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com • https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite • https://youtu.be/QDdC16Cz8tk?si=w7fyQ_YvoWltZnlL •1.8KViews2likes0CommentsStatic IP Address Configuration for AP Mode
This guide outlines how to use NETGEARs AP mode feature and use the AP Mode Static IP address configuration vs the Dynamic IP Configuration. Supported NETGEAR Routers: Nighthawk and Orbi Systems For Dynamic IP Configuration for AP Mode on Nighthawk or Orbi systems, users can refer to the following KBs: https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point Refer to these KB for router features that are supported and not supported while in AP Mode: https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode Pre-conditions: Host Router with DHCP Services enabled. Recommend having an adjusted DHCP IP Address pool range on host router to allow for static IP address configured devices to use IP addresses that are outside of the host routers DHCP IP Address pool range. Recommend the host router be configured for ###.###.#.100 thru ###.###.#.200. https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router This gives a good IP address pool size range for IP address reservation within the pool range and then also gives room on either side of the IP address pool range for devices that are static IP addressed configured which this is a standard networking practice. IP address range adjustments can be changed later. LAN cable to connect the host router to the NETGEAR router being configured to AP mode. ALL NETGEAR routers configured for AP mode require the WAN or Internet port to be connected to the host routers LAN port for proper operation when in AP mode. CAT6 recommended LAN cable. NETGEAR router running in router mode, or a factory reset may need to be performed to get the router back to default router mode and its web page accessible at 192.168.1.1 Ethernet wired PC or Laptop is recommended, connected to back of NEGEAR router to be configured for AP mode. Log into the NETGEAR routers web page at 192.168.1.1 or the IP address custom set if this differs from the default IP address, in a web browser. Navigate to the following location, Advanced tab/Advanced Setup/Router/AP Mode menu setting. Also, may be seen as Router Mode on some different model routers. Select on the AP Mode tile to select this mode for the NETGEAR router. Then select the APPLY button. Wireless AP configuration screen will appear in the web page: Select the Enable fixed IP Settings on this device radio button. This will display the IP Address, IP Subnet Mask, Gateway IP Address, Primary and Secondary DNS configuration input boxes: Configure the IP Address box for a static IP address number that is outside of the host routers DHCP IP Address pool range. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200. Example: Host router Default IP address pool range is set for 192.168.0.100 thru .200. IP Address set on NEGEAR router for AP mode is 192.168.0.50 Recommend making the static IP address intuitive. i.e. use the model number of the NETGEAR router in the IP address number in the last value. So, for a RBR850 or RAX120 model router, set a 192.168.#.85 or 192.168.#.12 static IP address. This IP address will not change unless the user changes it here. These addresses need to be outside of the host routers DHCP IP address pool range. Configure the IP Subnet Mask, Gateway IP Address, Primary and Secondary DNS configuration input boxes accordingly to what the host router is set for. Example: Host router IP Subnet Mask is 255.255.255.0 Host router Gateway IP Address is 192.168.0.1 Primary and Secondary can be either the Host routers IP address or use custom DNS IP addresses here, such as ISP service DNS, Google DNS, OpenDNS, Quad 9 DNS, Raspberry Pi DNS or any other valid DNS addresses can be used here. After input boxes have been filled in correctly and checked, select the APPLY button. The NETGEAR router will now begin a reboot cycle. Take a LAN cable and connect it to the WAN or Internet (yellow) port on the back of the NETGEAR router. Connect the other end of the LAN cable to an open LAN port on the back of the host router. Give about 2-3 minutes allowing for the NEGEAR router to process the AP mode configuration and come to ready. Observe for internet status LEDS on the router, that should give indication of the connection to the host router and getting internet services. Check the model router user’s manual for LED indication and behaviors. After the NETGEAR router has rebooted and come to ready, the ethernet connected PC should now have internet access and should be able to log into the NEGEAR routers WEB page that’s now in AP mode using the static IP address that was configured. After logging into the router’s web page, Operation Mode: Access Point should be displayed on the first main page: Navigate to the Advanced Tab/Advance Home and check the LAN Port section. IP Address, IP Subnet Mask, Gateway IP Address, Primary and Secondary DNS configurations should be displayed here for review. Users can now configure the wireless settings or configuration on the NETGEAR router as desired. Navigate to the Basic Tab/Wireless Settings web page to make changes here. Navigate to Basic Tab/Attached Devices. Verify any devices appear here that are connected to the NETGEAR router while in AP Mode. All ethernet and wireless connected devices will appear here: Check with all connected devices that they can connect to the NETGEAR router in AP mode. Verify they get internet services while connected. Recommend making a backup configuration to file for safe keeping of the AP Mode configuration. Saves time if a factory reset is needed or something happens. https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-System LAN Ports in back of the NETGEAR router configured for AP mode are functional and can be used for ethernet connected devices while in AP mode. Place NEGEAR router that’s in AP Mode into your desired or designated location for normal operation. Recommend 3-6 feet distance from other electronic devices.736Views0likes0CommentsOrbi App and Advanced WAN Configurations Setup FAQ
This is a guide for NETGEAR router users that have specific ISP WAN service configurations (STATIC IP or PPPoE) that are required by the ISP for a new router to be fully connected and used with these ISP internet services that have these specific ISP services. Pre-requisites: Orbi mobile app installed on Apple or Android mobile device. Phone or Pad. Recommend disabling any MAC Address randomizers while at home prior to starting the application: NETGEAR Mobile Applications and Apple Devices FAQ Have required ISP WAN Configuration information gathered from ISP at the ready. Consult with your ISP for this information. This is not used for Auto DHCP configuration ISP services. Connect the NETGEAR router to the ISP Modem/ONT. Recommend powering OFF the modem/ONT and router prior to connecting them together. Power ON both NETGEAR router and the ISP Modem/ONT. Modem/ONT should sync and come to ready and the NETGEAR router should come to a setup ready state. Launch the Orbi mobile app on your mobile phone or pad. If a log-in appears, this uses the NETGEAR account profile user name and log in information here that you may have already created on NETGEARS web site. Select New System Setup Select Your Product. Press Wi-Fi Orbi System for any RBR or RBRE series models: Scan the QR code or select Connect Manually. For scan QR code, point your mobile devices camera at the QR sticker that is attached to the top or front facing surface of the NETGEAR router. Continue with theOrbi app prompts to continue it's setup progress. On the Router Detected page, the app will display it's checking the Cables and Internet connection and service here: The Checking Internet will fail and report a problem. If there is a Try Again button seen displayed, select Try Again button. The check will fail and then present a Advanced Setup button. Select the Advanced Setup button: This will display Advanced Network Setup with two configuration options, Static IP and PPPoE: Select from either of these two options to configure the WAN configuration given by the ISP here: After ISP WAN Configuration has been entered correctly, Select the Apply button to have the Orbi app save and apply the new WAN configuration changes to the router. Continue and complete the Orbi mobile app setup wizard. After the setup wizard completes, check for internet services with your mobile Wi-Fi or wired PC devices. Consult with the ISP to confirm and ensure any ISP configurations are correctly entered and configured if the router fails to connect with the ISP services. This article applies to: All NETGEAR Orbi AC, AX, AXE and BE series routers.226Views0likes0Comments
