rs100
24 Topicsdns settings not being applied to clients
just got a new RS100 and none of the clients on my network (wired or wireless) will get the DNS IP that i put in. i have tried a number of different ones (my Pi-Hole server, google, Quad9), all clients get the IP of the router itself. i'm only using IPv4, have shut down clients and restarted the router, etc. nothing seems to work. am i missing something? i am using the router as a dhcp server. my older router has no issuesSolved249Views0likes6CommentsI'm getting ready to pull the trigger on an RS100
Sorry, i know this is a few months old, but i am curious about your comment as to why the RS200 would be better for this use case. I'm getting ready to pull the trigger on an RS100, but would like to separate my IoT devices, but still manage them with apps on my phone on my regular wifi setup109Views0likes3CommentsRS140 Previously configured device does not connect to the Wi-Fi network.
Hi, I have my company laptop and it ran out of battery while connected to my company's VPN. It also uses Cisco Anny Connect. After recharging, it won't connect to the Wi-Fi network with my RS140 router. I've already restarted the modem and router, and removed the network from the laptop. The other devices are still working fine.139Views0likes11CommentsI got RS 180, Please help
I am having same issue. Tried so many configurations like disabling protection, acl, IGMP, etc but still nintendo not working properly. Connection says it is connected but when running test but it errors out NAT - F and rest. I got RS 180, Please help.183Views0likes6CommentsStreamline Upgrade; Old NightHawk to New NightHawk
Background info - Recently received email from Netgear Support that my existing router (NightHawk AX1800 WiFi 6, serial# 689B0C7PA0131, purchased/installed March 2021) will no longer receive service updates starting May 2026. The email from Netgear Support suggested upgrading to a NightHawk WiFi 7 RS100 router. Appreciate the recommendation. Don't need to upgrade to a mesh router (small square footage building), have had excellent performance with the AX1800, would welcome upgrade to WiFi 7. I then proceeded to check on info at Netgear.com about the RS100 router. Difficulty - In order to upgrade from NightHawk AX1800 to NightHawk RS100, I will have to setup the newer RS100 router from 'scratch'. I will have to manually, configuration page-by-page, type in all my customized network configuration settings for the AX1800, one-by-one, that have accumulated over 5 years of use (lots of configuration info). The AX1800 router, if not all NightHawk routers, has the capability to output an encrypted, binary coded ".cfg" file that can be used to very quickly, painlessly, backup/restore all the configuration settings, etc, for the AX1800 -even to another AX1800 (if old router dies). HOWEVER, after visiting with Netgear chat support (both AI and human), NO such quick/easy option exists for UPGRADE of a NightHawk from an older to a newer model NightHawk (AX1800 to RS100). I cannot simply take the encrypted/binary coded .cfg file from my old, existing AX1800 (which has ALL my 5 years worth of configuration settings) and simply import/load that into a newer RS100 router (via the backup/restore feature). I realize the newer RS100, or any newer router especially going from WiFi 6 to Wifi 7, will have many, many new features/settings (ie, the .cfg file for a RS100 would probably be much, much larger and have many different, newer settings than the older AX1800). However, and maybe I am over-simplifying things, wouldn't the older AX1800 settings be somewhat of a smaller subset of the newer, more enhanced RS100 settings? Recommendation/suggestion/discussion - Would there possibly be some overlap, commonality between the .cfg files? If there was some commonality, would it be possible to have some kind of utility program that could take the AX1800 config settings in its .cfg file and 'seed them' into the proper format for the RS100 .cfg file? As to encryption, have the 'upgrade utility program/feature' use current unique encryption key for the AX1800 .cfg file to decode its info to plain text/ASCII, etc, and then use current unique encryption key for the RS100 to encrypt that info into a .cfg file for backup/restore into the RS100 (with the proper format, sequencing, etc). This would streamline the upgrade process from AX1800 to RS100 by an order of magnitude or more (mere minutes? using .cfg files versus much, much longer, having to manually by hand, page-by-page, type in settings with many, many more opportunities for errors). Surely other customers would also benefit from such an "upgrade feature" for their routers -especially if the utility program/feature could be made to work across different models for other router upgrades. I think the coding effort would be worth it for customers/end-users. If not incorporated directly or built-in for the router, then offer it for purchase as an router feature upgrade. Why not make it easier for the customer to upgrade, purchase newer models, be more user-friendly) -instead of causing the customer to spend more of his/her valuable time for setup when they have already the setup working on their existing router.327Views0likes8CommentsWPA2 on 2.4ghz overriding WPA3 on 5ghz band
I have a Wifi7 RS140 router. I've have some older smart plugs that only work with WPA2 security. No problem I just use the 2.4 band for those using WPA2. I have set the 5ghz band to WPA3 security for my phones yet when I connect to the 5ghz band I only get wifi 6 speeds (wifi 6 icon on phone). If I go back and change the 2.4 bands to WPA3 security then I get WIFI 7 speeds on my phone (wifi 7 icon) but no longer can connect the older smart plugs. I should be able to have to separate, independent bands each with their own security levels, no?272Views0likes6CommentsNighthawk RS100 vs RS300 - IoT devices
Hello! My goal is to have all of my IoT devices on a separate network. I've been googling and searching on this forum on whether or not nighthawk RS100 or RS300 can set up IoT devices on a separate network. So far what I've been learning is that RS100 - you can have IoT devices set up in the guest wifi network but no guarantee all IoT devices would work properly. RS300 - I've got mixed search results on whether RS300 has a separate IoT wifi network. some post/site say yes, others say no. my questions is if RS100 and RS300 both can only have IoT devices on the guest wifi network, then why should I spend more on the RS300 (I don't have faster speed and wider wifi range coverage). I would spend more on the RS300 if it has a IoT wifi network feature. Can anyone pls confirm which is which? which wifi router should I get? Thank you for your time! Tate840Views0likes8Comments
