rs70
3 TopicsRS700 pinging Google DND every 4-5 secs on AP Mode
I am currently using my RS700S in AP mode behind a pfSense firewall. I noticed the router is pinging 8.8.8.8 and 8.8.4.4 every 4-5 secs showing up in block alerts, more of nuisance than anything with it flooding the logs rather than any connectivity. I assume it's trying to check for an internet connection, but there needs to be a way to block/stop the RS700S when in AP mode. I assume this is not just the RS700 but other models probably doing the same as a lot of them share similar core firmware.733Views0likes10CommentsNeed Main 2.4G Network - Internet Access Only
I Would Like to Configure my Main 2.4G Network to be "Internet Access Only" just the same but without enabling a Guest Network "Specifically" to prevent them from competing with each other. I only need/want "One" active 2.4G network signal with Internet Access Only. Any help or suggestions would be greatly appreciated... Netgear Router RS70Solved225Views0likes10CommentsNetgear NH - RS70 (No USB ReadyShare)
Been using USB Readyshare on C7000v2 Modem/Router Combo since purchased a few years ago. Needed to add a new Separate Netgear RS70 router and it's clearly understood that USB Readyshare is deactivated when C7000v2 router mode turned off and put into "Bridge Mode - Modem Only" to work with the newly purchased RS70 router. However, I started thinking how I could get USB Readyshare to work if turned router mode back on and disabled all wifi signals and DHCP server to avoid conflict with new RS70 router. Works great when connected to PC only "without" new RS70 router, but once new RS70 router is added into the connections - unable to get any internet connection... So what am I missing?? Any Help or Suggestions are welcome... :-) Cat 5e from C7000v2 to PC gets internet and USB Readyshare works great. Cat 5e from C7000v2 to WAN port new RS70 router and Cat5e from new RS70 router LAN port to PC unable to get any internet connection thus no Readyshare either... Is there an IP Address needed on the RS70 Router or C7000v2 WAN or LAN settings?278Views0likes15Comments
